1. philantrenzo's Avatar
    i'm semi new to android and not the most tech savvy. i bought my s4 off craigslist. it is either rooted or has a custom rom (don't really know the difference). theres an update that keeps coming up in my notifications but it wont let me update it...any suggestions on how i can update?
    07-29-2013 03:16 PM
  2. Paul627g's Avatar
    First thing you can check to verify if its rooted is look in your app drawer and see if there is a SuperUser or SuperSU app which basically means the device is rooted.
    Also the other way to check is to attempt to boot into recovery and see what comes up.
    1. Stock recovery (usually very obvious and only a few simple options. If I remember correctly a black screen with BLUE text)
    2. Custom recovery like TWRP or CWM will boot up. This will be completely obvious if its installed because it will says TWRP or CWM and have a menu with many options.
    From a completely powered off state, press and hold Volume Up + Home Button + Power button together for a few seconds and it should boot you into one of the following above.
    07-29-2013 03:21 PM
  3. philantrenzo's Avatar
    thanks for the help! SuperSU is installed. TWRP came up when I rebooted...do you know how to accept the software update?
    07-29-2013 03:26 PM
  1. Link2SD could not obtain root access.
    By joelman0 in forum General Help and How To
    Last Post: 08-27-2013, 11:45 PM
  2. Apps disappearing from phone. Not from Google Play Store account.
    By intlzncster2 in forum Samsung Galaxy S4 Mini
    Last Post: 08-04-2013, 11:08 AM
  3. Problem with capacitive buttons on S3
    By Steviewy in forum Verizon Galaxy S III
    Last Post: 07-29-2013, 05:18 PM
  4. Replies: 2
    Last Post: 07-29-2013, 05:04 PM
  5. Update for LG Optimus Regard and android 4.1
    By Leonard Butler1 in forum Legacy Android & Other OS's
    Last Post: 07-29-2013, 02:07 PM
