1. Steve Swift's Avatar
    After a period of inactivity, the display blanks and the device locks.
    Is there a way to disable the locking mechanism, or perhaps set the inactivity timeout greater than 10 minutes?
    At the moment I'm learning about my new device, but it seems that I have to (swipe) unlock it at every interaction.
    07-30-2013 03:55 AM
  2. Rashawn29's Avatar
    Setting >mydevice>lockscreen
    there you'll see secured lock time
    Sent from my Galaxy S4 via Android Central App
    07-30-2013 06:43 AM
  3. fatboy97's Avatar
    Settings > My Device tab > Display > Screen timeout is actually where you can change the timeout... but 10 minutes is the max you can set this to.
    Settings > My Device tab > Lock screen > Screen lock > you can set this to None if you don't like the Swipe.
    Steve Swift likes this.
    07-30-2013 01:07 PM
  4. dacbeth's Avatar
    Play Store: NO LOCK
    07-31-2013 07:37 AM
  5. fatboy97's Avatar
    Loading an app, or just changing your settings to None... you have choices.... personally I prefer to not load more apps on my device than necessary... but I guess you have choices.
    07-31-2013 08:41 AM
  6. dacbeth's Avatar
    Thanks, missed that choice.
    08-01-2013 07:09 AM
  7. Steve Swift's Avatar
    Thanks. This is ideal whilst I'm familiarising myself with the device. In combination with the Samsung Flip Case cover, I have the perfect combination for me.
    08-04-2013 06:11 PM
  1. Always On...
    By NoYankees44 in forum Moto X (2013)
    Last Post: 07-30-2013, 09:05 AM
  2. Help on Sprint
    By Pink in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-30-2013, 01:37 AM
  3. Nexus lock animation?
    By Jtshurtleff in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-30-2013, 12:53 AM
  4. How to remove a user certificate on N4
    By aloaraycr in forum Google Nexus 4
    Last Post: 07-29-2013, 08:28 PM
  5. Restarts post lock screen after update ...
    By NabeShogun in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-29-2013, 08:08 PM
