1. noisemaker's Avatar
    Help! The Wifi setting window keeps appearing and it also keeps scanning. I wouldn't be surprised if I have some setting wrong, but I can't figure out what, and it's driving me crazy. "Notify me" is unchecked. "Auto-connect" is unchecked. "Keep Wifi on during sleep" is "Always". "Check for Internet service" is unchecked (no difference if it is checked). I am getting "very strong" signal strength. What am I missing? Thanks. -- Roy
    08-04-2013 02:12 PM
  2. Scott Kenyon's Avatar
    So to clarify, you're saying your wifi settings app is popping up no matter what you do/. That's a new one for me. I've never heard of such a thing. Perhaps you should try a factory reset.
    08-04-2013 06:28 PM
  3. noisemaker's Avatar
    Basically, yes. No matter what I do, unless I switch off wifi, and sometimes even then, depending on settings, it keeps popping up. I would hate to do a factory reset because the effort required to move back in. I have tried restart, cold start, and battery pull. Nothing helps. Is there some setting I'm missing?
    08-05-2013 09:15 AM
  4. HPferoxCraft's Avatar
    If you go under settings -> wifi -> smart mode, is that on?
    08-05-2013 09:21 AM
  5. Almeuit's Avatar
    What carrier? If you are on Sprint go under settings, mobile networks, and ensure the Sprint Connection Optimizer or whatever it's called is turned off. This can keep turning your wifi on.
    Sent from my T-Mobile HTC One using AC Forums.
    08-05-2013 09:22 AM
  6. noisemaker's Avatar
    Mea Culpa. I am embarrassed (once again) to admit it was a problem I created with Tasker. Thanks for the help.
    Scott Kenyon likes this.
    08-06-2013 09:57 AM
  1. Pics/Videos showing up blank/black in Gallery & won't open
    By seinx in forum AT&T Samsung Galaxy S4
    Last Post: 02-09-2018, 04:13 PM
  2. Yahoo Mail stops working on N4, what's up?
    By billdz in forum Google Nexus 4
    Last Post: 08-10-2013, 12:56 PM
  3. Wake me up when I can touch it.
    By Pollster in forum Moto X (2013)
    Last Post: 08-05-2013, 07:40 PM
  4. Can I use my phone as a remote when I am off my home WiFi network?
    By galatians51 in forum Google Chromecast
    Last Post: 08-05-2013, 02:11 PM
  5. Previous texts showing in pop up notification
    By gab0222 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 08-04-2013, 09:11 AM
