1. tigerfalcon007's Avatar
    Hey guys, here are some screenshots from GSAM and BBS. This is the typical battery life I get, is this normal? It doesn't seem any better than my EVO 3D was getting. Any advice on how to make it better would be appreciated. I'm on sprint, and my phone is not rooted.
    Attached Thumbnails Dismal battery life-screenshot_2013-08-05-19-20-42.jpg   Dismal battery life-screenshot_2013-08-05-19-20-50.jpg   Dismal battery life-screenshot_2013-08-05-19-20-56.jpg   Dismal battery life-screenshot_2013-08-05-19-21-15.jpg   Dismal battery life-screenshot_2013-08-05-19-21-35.jpg
    Dismal battery life-screenshot_2013-08-05-19-21-40.jpg   Dismal battery life-screenshot_2013-08-05-19-21-46.jpg   Dismal battery life-screenshot_2013-08-05-19-21-55.jpg
    08-05-2013 11:37 PM
  2. MagicMike Kelley's Avatar
    Not attempting to be a smartass here but battery savers can be battery killers and it looks like you've tried numerous.
    There are a number of tweaks you can make that should help. How often are you apps synching? FB, GMail, ESPN SC etc... Synching can be a big drain.
    SVoice > Settings > Wake up/Wake up command: This sets your phone to listen for your wake up command at all times and can be a battery killer.
    The above are a few examples I know of but I know there are some threads on here which really help you with optimizing your phone to prevent this drain.
    Good luck.
    08-06-2013 12:06 AM
  3. tigerfalcon007's Avatar
    I actually don't use and haven't used any battery saving software. Didn't think to disable SVoice, might as well since I don't use it.
    08-06-2013 12:20 AM
  4. harryhoudini66's Avatar
    I am confused. If you have used any, what is with all the screenshots showing different battery or app monitoring apps?
    Disable whatever you dont use:
      • S Voice
      • Air Gestures
      • Syncing
      • Lower Display brightness
      • Bluetooth
      • NFC
      • GPS
    Enable Power Saver
    Relletti likes this.
    08-06-2013 12:46 AM
  5. tigerfalcon007's Avatar
    Air gestures, NFC, and GPS are off. Bluetooth is only on in the car. Is that much battery drain normal?
    08-06-2013 12:52 AM
  6. garublador's Avatar
    It looks like a lot of it is going to having your screen be medium or brighter brightness. Try lowering your brightness to about 1/3 or so to see how much that helps.
    08-06-2013 08:24 AM
  7. Relletti's Avatar
    I notice on mine that the screen on the s4 is my main battery killer. So like others have said turn of the power saving mode and adjust the screen brightness and you should see a difference soon.
    Sent from my Galaxy S IV using Tapatalk IV
    08-06-2013 08:35 AM
  8. MagicMike Kelley's Avatar
    One thing to mention here, that will be a pain - is that if you are seeing 80% drain in a couple of hours with little use then I'd return it for a new one under warranty. I use mine for many things and have had good battery life. I do NOT have everything disabled (then again not everything is enabled either) nor do I have power saving mode on.
    What you're seeing is definitely not "the norm"
    08-06-2013 09:11 AM
  1. Replies: 6
    Last Post: 08-07-2013, 12:48 AM
  2. Is there something wrong with my battery?
    By blessedred in forum HTC One M7
    Last Post: 08-06-2013, 03:53 PM
  3. Netflix destroys battery
    By Dizzo1992 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-06-2013, 12:31 PM
  4. Battery life on Galaxy s4???
    By Cesar Antonio in forum Samsung Galaxy S4
    Last Post: 08-06-2013, 08:33 AM
  5. Replies: 0
    Last Post: 08-05-2013, 08:57 PM
