1. Omer San Gabriel's Avatar
    I've tried using the motion to silent setting but what happens i can't hear some calls, my phone is often in my bag when i travel and sometimes i think it silents it self without me turning it down.
    Please Help. Thanks
    08-06-2013 05:10 AM
  2. Almeuit's Avatar
    Wait... Are you trying to silent the phone or not?
    Sent from my T-Mobile HTC One using AC Forums.
    08-06-2013 08:20 AM
  3. SpookDroid's Avatar
    There are a few ways to 'silent' the incoming call. One is by pressing the volume rocker or the power button, which is probably what happens most often if inside your bag.
    Also, if the motion setting is on and the phone is in your bag and it's moving around too much, it MAY trigger the silencing by thinking you turned the phone down. Remember that it uses both the motion sensors and the proximity sensors, and if you're using the flip cover (which doesn't latch close) the flapping, even if slight, can cause the phone to sense that the IR sensor was unblocked and is now blocked. I know, for instance, that sometimes the 'wave your hand to answer' is triggered by this in rare occasions.
    skidoo and Almeuit like this.
    08-06-2013 10:21 AM
  4. Omer San Gabriel's Avatar
    Just trying to silent the incoming call.
    That's the problem i'm having. Sometimes i guess it's triggering the silence by motion when my phone is shaking in my bag = i can't hear the incoming call.
    I don't want to silent my phone all the time, but sometimes i just want to just silent an incoming call and let it ring instead of rejecting a call.
    08-06-2013 11:45 PM
  5. fantom305's Avatar
    Well as far as I know, you have to do it manually if you want to choose and pick which call you want to accept or not. When the phone rings what you do is swipe the red X and the phone will stop ringing but it will go through the motions like if you normally did not answer it for the other person . Unless you want to put that particular number under the blocked settings at certain times of the day or night ..........
    08-06-2013 11:55 PM
  6. smooth4lyfe's Avatar
    I know incoming calls are silenced when u press the volume buttons
    Sent from my Galaxy S4 Exynos via Tapatalk 4... I LOVE THIS PHONE
    08-07-2013 01:31 AM
  1. Problem Updating my HTC one due to region
    By saitomi0627 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 12-19-2015, 04:24 PM
  2. Problem Updating my HTC one due to region lock
    By saitomi0627 in forum HTC One Series
    Last Post: 08-14-2013, 01:49 PM
  3. Syncing contacts and calendar from phone's memory to Google
    By czdraconis in forum General Help and How To
    Last Post: 08-06-2013, 09:25 AM
  4. [tf700t] What in my software is keeping any gamepad from working?
    By Nebrethar in forum General Help and How To
    Last Post: 08-06-2013, 01:50 AM
  5. Best way to bypass youtube not avaiable on mobile
    By CBR9927 in forum Samsung Galaxy Note 10.1
    Last Post: 08-06-2013, 01:08 AM
