1. mshoab's Avatar
    Hi. I was a happy owner of a Samsung Galaxy S4 when all of a sudden my phone stopped accepting the files I tried to copy from my PC to its Card. The file copying process starts but never ends.
    All the settings are checked, nothing changed, no dropping the phone ... then Why?
    Can anyone plz HELP
    08-07-2013 02:48 PM
  2. T Android's Avatar
    Can anyone plz HELP
    Is the memory card full?
    - - - Updated - - -
    You can try out Kies, to move your data from the computer to your Samsung Galaxy S4.
    08-07-2013 02:50 PM
  3. Almeuit's Avatar
    Any errors or anything? Does the SD card still work for taking files off it? Also how are you transferring them?
    Sent from my T-Mobile HTC One using AC Forums.
    08-07-2013 02:54 PM
  4. mshoab's Avatar
    Thanks for some kind of response.
    Well I am transferring file through USB data cable connection. Some of my programs installed on my phone are using the SD Card and are not reporting any problem. I have noticed that I can copy files from the SD Card and internal memory but CANNOT copy TO both the memories through USB. The phone is accepting files through blue tooth connection to my PC.
    08-17-2013 09:00 AM
  5. Joe Vile's Avatar
    Do you have a SD card adapter ( micro SD to standard SD) try using that instead of a cable
    08-17-2013 09:16 AM
  1. Who's pre-ordered and what phone are you coming from?
    By kilofoxtrot in forum Motorola Droid MAXX
    Last Post: 08-23-2013, 11:08 PM
  2. Where is the UPS guy! Awaiting my Nexus 4!!!
    By rexbaumgartner in forum Google Nexus 4
    Last Post: 08-10-2013, 12:20 AM
  3. Will a car mount for the Galaxy Note work for an S4??
    By shinsen1378 in forum Samsung Galaxy S4
    Last Post: 08-07-2013, 07:51 PM
  4. email notification not working, What is the fix for this.?
    By Jonathan Schwarz in forum Droid RAZR HD
    Last Post: 08-07-2013, 12:20 PM
  5. Blue light problems
    By Alex Pelkey in forum Samsung Galaxy S4
    Last Post: 08-07-2013, 09:32 AM
