1. aj888's Avatar
    So if anyone one is looking to save on a battery and have a nice case. I bought the seidio extened case on amazon along with the hyperion extened battery at 5200mah. It was 28 for the battey not 60 for the seidio. I have seen some people cut there otterbox to make it work. But this is the easy was. The fit is perfect. Even thought the battery is 700mah bigger doesnt take up anymore room in the case. Hope this helps
    cyberchief likes this.
    08-07-2013 08:08 PM
  2. cyberchief's Avatar
    Which Seidio extended case did you get specifically? Curious if any of them will work. I have the Hyperion 5200 battery (and case) arriving today... but only saw the issues with the case this morning.. now looking for alternatives.
    I had the Mophie on my GS3... I loved it and wish they had a model for the S4... but what can you do.
    08-08-2013 08:02 AM
  3. aj888's Avatar
    Its the case for there 4500mah battery. http://www.seidioonline.com/samsung-...ssgs4xk-bk.htm
    You dont need there battery just the hyprion one.
    08-08-2013 08:06 AM
  4. cyberchief's Avatar
    Thanks! Great info! Ordering one now!
    08-08-2013 08:46 AM
  1. Samsung Galaxy S2 GT-I9100 JellyBean 4.1.2 XXMS2 Battery Life
    By ronhill in forum Samsung Galaxy S II
    Last Post: 01-09-2014, 05:55 AM
  2. Issue with Motocast
    By Lonewolf147 in forum Motorola Droid 4
    Last Post: 08-19-2013, 05:43 PM
  3. Excellent Q&A with MotoX engineer
    By TheLibertarian in forum Moto X (2013)
    Last Post: 08-09-2013, 03:34 AM
  4. How to record video with S View case closed (screen off)
    By fillerton in forum Samsung Galaxy S4
    Last Post: 08-08-2013, 11:27 AM
  5. Words with Friends is going too far with it's ads
    By meyerweb in forum Android Apps
    Last Post: 08-07-2013, 07:01 PM
