1. Adam Goodison's Avatar
    Would anyone be able to recommend based on personal experience a good third party wireless charger and receiver, please?
    08-09-2013 05:44 PM
  2. Raptor007's Avatar
    Well I would start with the wireless charging battery door from Samsung, I know you can add 3rd party pieces to the current battery door but shortcuts always end up costing more in the long run. As for the wireless chargers themselves as long as its Qi-enabled you should be good to go. You can easily find LG, Nokia, Samsung, Duracell, Energizer, and many others. PhoneArena had this article 10 wireless charging pads for Qi-enabled smartphones and the thought the OregonScientific Clock/Charger station was a cool one but not for $160+ I would do a quick search on Amazon.com and look for some closeouts as well.
    Also if you didn't register your phone with Samsung you should. They will send you a nice $50% off code for accessories up to $49.99 which won't include the charger pad but will cut the cost of the battery door down.
    A quick check of Amazon.com Amazon.com: Qi-enabled shows some options for about $35 and that Oregon Scientific one I mentioned above, well Amazon.com has it for $92.28 so not bad.
    Adam Goodison likes this.
    08-10-2013 03:06 PM
  3. benhmadison's Avatar
    Raptor did you switch to the S4? I saw your sweet deal on your DE ONE
    Sent from my Google Play Edition HTC ONE.
    08-10-2013 03:30 PM
  4. Adam Goodison's Avatar
    Thanks very much for your detailed post, much appreciated. I'll check out that link now.
    08-10-2013 04:18 PM
  5. Raptor007's Avatar
    You are very welcome. I am considering wireless charging, just not sure I want to spend the extra coin on it or not.
    08-11-2013 06:41 PM
  6. DSWR's Avatar
    QI Wireless Charging Pad For iPhone Samsung Nokia & All Qi Enabled Devices | eBay
    This is what I use, 22 for everything you'll need. Your phone doesn't become fatter, doesn't cost you the price of the moon and does the job effectively.
    08-11-2013 08:11 PM
  1. [APP]&[GAME] FLASHLIGHT and LUDO
    By azodus in forum Android Apps
    Last Post: 12-05-2014, 10:29 AM
  2. [LWP] OXON Live Wallpaper 2D and 3D
    By Stepan Ignatov in forum Android Apps
    Last Post: 12-06-2013, 04:08 AM
  3. and G
    By Channan in forum General Carrier Discussion
    Last Post: 08-15-2013, 12:50 PM
  4. Missing EXIF data on photos and videos - anyone else?
    By Eleanor Glanville in forum HTC One M7
    Last Post: 08-11-2013, 05:14 PM
  5. Best Buy & Chromecast
    By prissysox in forum Google Chromecast
    Last Post: 08-09-2013, 09:19 PM
