1. colbygatte's Avatar
    I recently updated my phone, and now I can't put the shortcuts widget on the home screen. This is the options I'm given. The camera shortcut option is disabled...
    08-11-2013 10:34 AM
  2. srkmagnus's Avatar
    Look through the settings and see if by chance you disabled lock screen widgets. I'm guessing this might be the cause of the problem.
    08-17-2013 12:34 AM
  3. HPferoxCraft's Avatar
    You need to back out a page and select 'multiple widgets'. If you cannot select multiple widgets then you have security enabled on your lockscreen other than just swipe.
    08-17-2013 08:42 AM
  1. Replies: 3
    Last Post: 08-23-2013, 09:09 AM
  2. Replies: 3
    Last Post: 08-13-2013, 08:06 AM
  3. Replies: 1
    Last Post: 08-11-2013, 08:18 PM
  4. Screenshot on samsung galaxy ace
    By realisticgirl in forum Samsung Galaxy Ace
    Last Post: 08-11-2013, 02:17 PM
  5. not finding push to talk on Galaxy Tab onscreen keyboard
    By ShaggyKids in forum Samsung Galaxy Tab
    Last Post: 08-11-2013, 10:32 AM
