1. natedog155's Avatar
    I don't have any screen shots of it yet because it always dies so quickly, but for some reason my battery dies in about 3 hours overnight. The only app showing usage is gallery. Its not set to upload photos unless its plugged in and hooked up to wifi. Tomorrow I'm waking up early so I'll hopefully catch it before it dies. Has anyone else noticed this problem? The battery lasts very long during the day but I usually charge it to at least 90% before I go to bed so it should have easily lasted the night.
    08-14-2013 11:02 AM
  2. fatboy97's Avatar
    Did you load any new apps, or change anything recently... even download any updates to apps?
    08-14-2013 11:10 AM
  3. tytlyf's Avatar
    Did you go into Gallery and it's settings to turn off sync for picture accounts?
    08-14-2013 11:49 AM
  4. garublador's Avatar
    It's a good idea to figure out what it is that's causing that so you can decide if you want it happening or not, but the short term solution is super simple. Just plug in your phone at night.
    08-14-2013 11:55 AM
  5. natedog155's Avatar
    I had a few new apps such as a live wallpaper, openmic + (it was off and didnt drain like that during the day), Venmo, boat browser, swipe home button and adobe flash. I uninstalled a few of the fishy ones like open mic + and the live wallpaper
    08-14-2013 07:20 PM
  6. Hikmat abdoollayev's Avatar
    I'd recommend trying to monitor sleep state with "Wakelock detector"
    You will have an access to see what keeps your phone awake and drains your battery while your phone is idle.
    The app is available in Playstore free of charge
    09-16-2013 01:35 AM
  1. Screen battery usage high?
    By mdogfizzle in forum AT&T Galaxy S III
    Last Post: 04-10-2016, 10:42 PM
  2. Using automation apps to save battery (and which one works best)
    By LeoRex in forum General News & Discussion
    Last Post: 06-05-2015, 12:21 AM
  3. Battery Helper (Saver) Apps
    By grkmnl in forum Samsung Galaxy S3
    Last Post: 08-17-2013, 09:41 AM
  4. Worst battery drain ever!
    By Rounak Patel in forum General Help and How To
    Last Post: 08-13-2013, 10:40 PM
  5. S4 battery water indicator false
    By mynameiserich in forum Samsung Galaxy S4
    Last Post: 08-13-2013, 10:33 PM
