1. TTheInfamous1's Avatar
    This has never happened before. All of a sudden its always an ongoing process now. I don't want to disable it because I do use once in a while, but I also don't want it running all of the time. Any suggestions? I didntv see anything in the application settings either.
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    08-14-2013 02:49 PM
  2. rydeordie2302's Avatar
    Same problem here. Must have had an update that caused this to happen. Hopefully someone can find a fix
    Weddas84 and brianphrack like this.
    08-14-2013 09:52 PM
  3. TTheInfamous1's Avatar
    That's what I'm figuring as well. For now I'll disable it. I don't want to but I don't want it to always run.
    08-15-2013 10:01 PM
  4. jeffreii's Avatar
    WatchON settings: disable "show remote control on notification panel" and turn off "auto display remote control on lock screen".
    Should be pretty much dormant unless you have the app open.
    kenm7711 and MeggieLM3 like this.
    08-16-2013 12:05 AM
  5. TTheInfamous1's Avatar
    Thanks for that. It worked out and I haven't had any issues. It's no longer always running.
    08-31-2013 11:21 PM
  6. Ar Jr's Avatar
    I tried to download watch on on google play store...
    its says your device isnt compatible with this version..
    please tell me why????
    My device is samsung galaxy tab 3 8.0 with ir commad..
    11-25-2013 02:43 AM
  7. androidlovesapple's Avatar
    You have to have a Samsung tab s or get or newer device
    02-05-2015 12:46 AM
  8. osvanberg's Avatar
    Just use Greenify and Greenify the damn thing. Problem solved.
    02-05-2015 07:52 PM
  1. Sync Bluetooth Problem Samsung Galaxy S3 Please Help!!
    By willo90 in forum Legacy Android & Other OS's
    Last Post: 11-14-2013, 04:40 PM
  2. Samsung Galaxy S4 Screen or software issue
    By David Sandoval1 in forum T-Mobile Samsung Galaxy S4
    Last Post: 08-14-2013, 04:14 PM
  3. Samsung Galaxy S 4 International Version
    By systum9 in forum Samsung Galaxy S4
    Last Post: 08-14-2013, 03:24 PM
  4. Please help - What is this button on my phone?
    By Adolf Satzinger in forum General Help and How To
    Last Post: 08-14-2013, 02:47 PM
  5. SAMSUNG S4 Who can't keep a charge
    By rjkgr in forum Samsung Galaxy S4
    Last Post: 08-14-2013, 02:30 PM
