1. tielerjon's Avatar
    I'm using nova launcher on my stock s4. I have a uccw widget on my lock screen but it is really small. I have the widget size set to 4x4 but it is only that size when I slide down on it, the rest of the time it's more like 2x2. Any ideas?
    Attached Thumbnails lock screen widget too small-screenshot_2013-08-16-09-57-21.jpg
    08-16-2013 09:05 AM
  2. gekkeiju's Avatar
    I also have this problem on my xperia z with zoopler widget- the widget is tiny when i press the wake button on my phone, but if it scroll to one side and back then it gets bigger again. It's no good when it's small as I can't read the writing! No idea what's wrong, I've tried changing the font size and everything, but there doesn't seem to be the option to resize or move widgets on the lock screen
    09-15-2013 10:01 AM
  3. garublador's Avatar
    I think it's just how Android handles lock screen widgets. There have been threads about this with DashClock, too. I haven't tried it yet, but something like WidgetLocker might let you customize how the widgets on the lock screen work a lot more.
    09-16-2013 10:07 AM
  1. [solved] my touch screen isn't working
    By 209219010 in forum Samsung Galaxy S3
    Last Post: 02-22-2018, 09:52 AM
  2. any way to mimic bottom 3 buttons on screen?
    By pjoseph in forum Samsung Galaxy S4
    Last Post: 09-09-2013, 04:45 PM
  3. Replies: 32
    Last Post: 08-20-2013, 12:43 PM
  4. 4.7 vs 5in screen differences
    By daveh98 in forum HTC One M7
    Last Post: 08-16-2013, 10:24 PM
  5. Looking for help with Zooper Widget
    By heath patrick in forum Android Apps
    Last Post: 08-15-2013, 08:08 PM
