1. ScreenOnOMFG's Avatar
    Last night I went to sleep with only wifi+sync, woke up after 9hours too see the battery only drop 10%. pretty acceptable to me.
    HOWEVER, once I woke up I was browsing the internet for a hour just to see my battery drop 15%
    The on-screen time is the only thing that kills my battery, I can play music half hour with max volume and it doesn't even affect my battery by 3%, because it's off-screen.
    Well just when I was typing this reply... My battery lost another 1% just staying on my battery history chart.
    You can see from the picture how the battery RAPIDLY declined when the screen is on.
    08-16-2013 11:17 AM
  2. garublador's Avatar
    That's perfectly normal. If you're getting a 15% drop for an hour of screen time you're getting pretty good battery life for a smart phone.
    08-16-2013 11:19 AM
  3. Almeuit's Avatar
    Also I see a play icon in the top left... Did you have music going as well? I'd assume your streaming since the wifi connection is actively transferring while you took that screenshot.
    Sent from my T-Mobile HTC One using AC Forums.
    08-16-2013 01:23 PM
  1. MHL (HDMI Out) on Moto X?
    By pchoi94 in forum Moto X (2013)
    Last Post: 09-26-2016, 01:12 PM
  2. New Nexus 7 2013 Screen HD Block Pixels
    By JakRox in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-01-2013, 02:09 PM
  3. I just have to say.......
    By Nychotxxx in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-21-2013, 03:34 PM
  4. Replies: 1
    Last Post: 08-16-2013, 04:29 PM
  5. AT&T Releasing phone on August 23rd!
    By earsly in forum Moto X (2013)
    Last Post: 08-16-2013, 10:54 AM
