1. gahendo's Avatar
    Just got a Att S4 and wondering if i'm missing a setting. On my iphone if I was on a call with my BT headset and got in the car it would auto connect to the car when I started it and when I shut the car off it would reconnect to the headset.. On the s4 I have to manually switch it. Same thing in my wifes car. Mine is a ford f150 and it's software is up to date and hers is a Toyota also up to date.
    Thanks
    08-17-2013 02:24 PM
  2. leathernuts#WP's Avatar
    It's the s4. My friend switched from his iPhone 5 to an s4 and said that is the one thing he misses.
    gahendo likes this.
    08-17-2013 02:27 PM
  3. gahendo's Avatar
    Bummer.. I was afraid of that being the answer.
    08-17-2013 02:31 PM
  4. sad cricket's Avatar
    I will suggest that you go to the Playstore and download some bluetooth apps. Some work better than others but I really like the Watch my Bluetooth app. You can configure the app to your liking. For an example, I have my configured to connect or disconnect automatically to my car's bluetooth when it identifies my wifi at home.
    08-17-2013 04:37 PM
  5. Tom Lamb's Avatar
    Just got an S4, and mine does auto connect, and disconnect when the car is turned off. I've got a Ford Edge and the software is up to date. I doubt very seriously that Samsung would remove such an important feature from their phone. Good Luck!
    09-12-2013 10:18 PM
  6. mandis's Avatar
    so my old Samsung would auto connect when I got into my car, but for some reason, I have to ask my car to connect every time with my new S4. is there a setting I'm missing on the phone?
    09-23-2014 10:01 PM
  1. Replies: 59
    Last Post: 05-29-2016, 10:15 PM
  2. LG HBS-730 Bluetooth Stero Headset Problems - The 700 was Fine!
    By bigberries in forum Verizon Droid DNA
    Last Post: 08-19-2013, 11:11 PM
  3. Using bluetooth with earphones
    By cc_trkr in forum Samsung Galaxy S II
    Last Post: 08-17-2013, 01:58 PM
  4. bluetooth
    By mcorvese2001 in forum Samsung Galaxy Tab 2
    Last Post: 08-17-2013, 10:14 AM
