05-23-2014 04:18 PM
28 12
tools
  1. STARGATE's Avatar
    any ideas on what to do ?
    I would just factory reset if it was me!
    But you could try these first:
    Clear Google search history
    Clear System process
    Clear the cache for all applications
    Clear Google Maps search history
    Clear browser history
    Clear the clipboard data
    Clear Gmail's search history
    Clear market search history
    And after that turn it off, take the battery out and wait a few seconds. Then, place battery back in and turn the phone on.
    Let it run for a few hours and then check to see if Android System is still consuming so much battery.
    Let us know if that helps you or not.
    Like I said, I would just factory reset to see if that takes care of that.
    Anyway just let us know.
    Sent From a Galaxy S4 Away!
    08-24-2013 09:10 AM
  2. cindyr98296's Avatar
    can't seem to stop maps from continuing a navigation when I'm done - navigation voice continues giving commands while I make phone calls, etc...help!
    05-23-2014 04:17 PM
  3. cindyr98296's Avatar
    I can't seem to stop maps from continuing a navigation when I'm done - navigation voice continues giving commands while I make phone calls, etc...help!
    05-23-2014 04:18 PM
28 12
  1. Deleted camera folder on Galaxy S4
    By robertbobert in forum Samsung Galaxy S4
    Last Post: 08-23-2013, 09:36 AM
  2. Google Play Music widget not responding to taps
    By smoledman in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-22-2013, 01:35 AM
  3. Galaxy S3 battery drain
    By Calvin Retterath in forum Samsung Galaxy S3
    Last Post: 08-19-2013, 11:17 AM
  4. S4 sleep have miscall and text vibrate when touch
    By 13wiL6sic6 in forum Samsung Galaxy S4 Active
    Last Post: 08-19-2013, 09:33 AM
