1. csn187's Avatar
    Hi does any 1 no why driving mode keeps coming on when i connect to wi fi?
    08-19-2013 07:25 AM
  2. STARGATE's Avatar
    I've never used it before. Don't see the need for it, but, are you sure you have disabled it?
    Sent From a Galaxy S4 Away!
    08-19-2013 07:54 AM
  3. csn187's Avatar
    Well i turn it off in the options but it just keeps coming back on every time i connect to wi fi
    08-19-2013 08:51 AM
  4. SpookDroid's Avatar
    Do you have an automation app like Tasker or something like that? It just sounds weird... If you don't use Driving Mode at all, you could also disable it entirely (Settings/More/Application Manager, go to the "All" Tab and look for Driving Mode, click on it to go into the settings and select "Disable". This prevents the app from running at all and it even removes it from our app drawer. Should you want it back, you do the same but the app will show up at the very bottom of the All tab).
    csn187 likes this.
    08-19-2013 11:59 AM
  5. STARGATE's Avatar
    This ^^^
    :thumbup::beer:
    08-19-2013 12:58 PM
  6. csn187's Avatar
    No dont have anything like that it just started doing it one day and couldnt get it to stop.. i dont use it any way so i'll do what you've said and put a stop 2 it that way lol
    08-20-2013 05:19 AM
  7. STARGATE's Avatar
    The last resort, if you feel up to the task, would be a factory reset. I had certain problem about a week ago, small but it was nagging me. So I did a factory reset, and no problems ever since!
    If you do so, make sure everything is backed up.
    08-20-2013 06:34 AM
  8. jarettp's Avatar
    there's a location menu in your settings. if you have your car location set to your wifi it's going to activate driving mode.
    08-20-2013 10:48 AM
  9. SpookDroid's Avatar
    His problem is the other way around Jarettp; his Navigation mode is coming up from enabling WiFi...
    08-21-2013 02:11 PM
  10. STARGATE's Avatar
    Hey, have you fixed the problem?
    Just for the heck of it, go to Settings, More, Location Services, My Places and see if Car is enable.
    08-25-2013 12:17 PM
  11. John Edelmann's Avatar
    This was my problem .. I didn't know what I was doing when I selected WIFI for "car" ... I have a 2007 Audi a3, and it DOESN"T have WIFI ... so my bad ... I said "NONE" in the CAR location setting (settings - more - location services, my places - car - NONE) and the issue is resolved.
    whew...
    john.
    11-03-2013 10:38 PM
  1. WiFi stuck "turning on"
    By ZephyrsDream in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-12-2018, 02:14 AM
  2. HELP!!! Synergy ROM flashing error!!! Phone wiped clean. Have download mode and clockwork recovery.
    By Kiran Chandra in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-21-2013, 11:22 AM
  3. WIFI tethering
    By devpunjabi92 in forum Android Apps
    Last Post: 08-19-2013, 02:27 AM
  4. Wifi
    By chcub1 in forum General News & Discussion
    Last Post: 08-18-2013, 08:24 PM
  5. Safe mode
    By chloeshotmom in forum Samsung Galaxy S4
    Last Post: 08-18-2013, 07:07 PM
