tytlyf
Google services could be the Google Now, Google + and other preinstalled programs by google. You may want to disable the ones you never use and additionally, open up the ones you do use and then go into their settings. From there you should be able to adjust syncing periods etc. I'm guessing you have some apps running and continually trying to sync.
