1. Kathryn Mary's Avatar
    A small amount of water got onto my phone and now the sound is muffled. There doesn't seem to be any other damage aside from this. Is there anything I can do to fix this? I don't have insurance on the phone, so I can't just get another one.
    Thanks.
    08-20-2013 11:49 AM
  2. Paul627g's Avatar
    Even though its probably little late now you could try putting it in a bag of dry rice for a day and see if it draws any remaining moisture out.
    Second.. I haven't pulled apart a newer device like the S4 but in older Galaxy S devices replacing the speaker was very simple once you took the screws out and pulled the phone backing off... Literally a small screw holding the speaker in place and follow the wire harness to where it plugs into the motherboard. No special tools were needed and it could be replaced in a few minutes.
    So if your handy and feeling up to the challenge you could search out a new replacement speaker online from Amazon or eBay...
    08-20-2013 11:58 AM
  1. Replies: 25
    Last Post: 01-22-2014, 01:14 PM
  2. Is it just me and Andrew Martonik or...
    By Mac58 in forum Moto X (2013)
    Last Post: 08-25-2013, 09:46 AM
  3. Just switched from iPhone 5 and HATING the battery. Any suggestions?
    By Andrew Grafeman in forum Sprint Samsung Galaxy S4
    Last Post: 08-23-2013, 03:56 AM
  4. Is there a 'start from zero' tutorial?
    By calvin2 in forum Verizon Galaxy Note 2
    Last Post: 08-20-2013, 07:05 PM
  5. Can I manually update my HOX to 4.2.2?
    By Craig1994 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-20-2013, 11:14 AM
