1. PrincessCar's Avatar
    Hi! Which should I choose if I want to save battery on my S4? Activating the auto brightness option or disabling it? Thanks!
    08-20-2013 06:30 PM
  2. fishepa's Avatar
    I think automatic.
    Sent from my SCH-I545 using Tapatalk 4
    PrincessCar likes this.
    08-20-2013 10:22 PM
  3. smooth4lyfe's Avatar
    Auto Brightness actually waste more battery because the phone is constantly trying to adjust to the light... I'd leave it off, but have a toggle widget that can change ur brightness to a specified level with one click... It's easier and saves battery... There are plenty in the Play Store
    Sent from my Galaxy S4 Exynos via Tapatalk 4... I LOVE THIS PHONE
    srkmagnus and PrincessCar like this.
    08-20-2013 11:25 PM
  4. srkmagnus's Avatar
    I agree with smooth. Set the brightness as low as possible while maintaining a reasonable visibility. You'll keep the screen from constantly switching to the brightest setting, which isn't necessarily needed in all situations.
    Sent from my SPH-D710 using Tapatalk 2
    08-20-2013 11:45 PM
  5. PrincessCar's Avatar
    Thank you guys! I guess I'll disable the auto brightness option. The S4 is such a great phone!!! Been a blackberry user for years and I am so glad I made the switch!
    08-20-2013 11:52 PM
  1. Picasa auto backup
    By valpd in forum Google Nexus 4
    Last Post: 08-27-2014, 08:53 AM
  2. phone auto answering
    By smokinHawk in forum Samsung Galaxy Note 2
    Last Post: 09-11-2013, 11:11 AM
  3. auto rotate
    By David_LFC in forum HTC One M7
    Last Post: 08-22-2013, 11:42 AM
  4. Sound menu has disappeared from Settings
    By Mark Bossanyi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-20-2013, 06:37 PM
  5. auto correct feature
    By darkserpant in forum Samsung Stratosphere
    Last Post: 08-19-2013, 11:29 PM
