1. androidgirl19's Avatar
    I ordered a Fintie s view case for s4 in the mail. I got it because I wanted a place to have my drivers license and debit card when I only want my phone with me. It has a nice little pouch in the inside for it. But I can't get S view to work? The reviews said it worked. It says it had auto sleep/ wake function. Help am I doing something wrong do I need to change the settings or does this case just not work?
    08-21-2013 04:14 PM
  2. androidgirl19's Avatar
    Help y'all this has been bugging me all day
    08-21-2013 04:30 PM
  3. danhartman26's Avatar
    I don't have the s-view cover, but under settings>My device>accessory there is an option for automatic unlock - if you don't have that checked, I don't think the cover will work properly...
    Again, I don't have the s-view, but I see that setting.
    Posted from my KFHD via Android Central App
    08-21-2013 05:04 PM
  4. vferrari's Avatar
    This ^
    Sent from my GT-N8013 using Android Central Forums
    08-21-2013 06:29 PM
  5. androidgirl19's Avatar
    Thanks guys I do know about that setting and have had it on and it still won't work the weird thing is that when I first got the case and hade it on it worked once but then never worked again
    08-21-2013 07:55 PM
  6. fkpalm's Avatar
    Did you try to reset the device
    Sent from my SPH-L720 using AC Forums mobile app
    08-21-2013 10:22 PM
  7. zoooN's Avatar
    Google how to "activate" S-View without a case to see if you can trigger it that way, to check.
    If not, go to a store and ask to try a normal S-View cover. Might be that your cover blocks the magnet. Idk.
    - Sent from my Galaxy S4 -
    08-22-2013 05:57 PM
  1. Gmail email notification/push not working?
    By angry mustache in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-30-2013, 11:58 PM
  2. Replies: 10
    Last Post: 08-25-2013, 06:53 PM
  3. is anyone working on getting root?
    By gamewarden3006 in forum Droid MAXX Rooting, ROMs, & Hacks
    Last Post: 08-23-2013, 09:03 AM
  4. The New Droid Works With ATT Sim
    By pirarre in forum Motorola Droid MAXX
    Last Post: 08-22-2013, 11:28 PM
  5. Belt holster/case for the Moto X ?
    By NealJ777 in forum Moto X (2013)
    Last Post: 08-22-2013, 08:25 AM
