1. wyldkytten's Avatar
    Whenever I put my S4 in the car dock, the phone does recognize it is in the dock. I also use the developer option for it to Stay Awake while charging. The problem is, even though I have Stay Awake checked, the screen still dims. It doesn't go to sleep, but the dimming makes it difficult to see any apps open at the time. This isn't app specific, it will dim on every app or even just the home screen if no apps are open.
    If anyone knows of a setting I need to use to keep this dimming from happening I would be very grateful.
    08-27-2013 02:13 AM
  2. B. Diddy's Avatar
    Do you have Power Saving Mode on? How to Make Your Galaxy S4 Battery Last Longer - LAPTOP Magazine
    If that's not the issue, maybe try Dim Lock?
    wyldkytten likes this.
    08-27-2013 02:40 AM
  3. wyldkytten's Avatar
    Nope, I already turned the power saving mode off. I'll give that Dim Lock a try, see if it can do anything.
    08-27-2013 10:59 AM
  1. Moving to SW Nebraska, need opinions
    By Audiyoda in forum Verizon
    Last Post: 09-29-2013, 11:15 AM
  2. Galaxy nexus stuck up at boot screen (phone not rooted)
    By Wirelessdroid in forum Google / Samsung Galaxy Nexus
    Last Post: 08-28-2013, 03:42 PM
  3. Stuck in a TWRP loop on startup!! I'd very much appreciate some help :(
    By JKforUA in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 08-28-2013, 12:50 PM
  4. Replies: 2
    Last Post: 08-27-2013, 08:25 PM
  5. A couple of home screen app icon oddities I'd like to ask about
    By douglerner in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-27-2013, 01:13 AM
