1. velocitysc43's Avatar
    I've had my phone for a few weeks now and notice that it gets very hot when I'm using it to browse the internet. I've read posts on these forums as well as some other sites that give suggestions on what to do to help the over heating issue. I feel like I've tried EVERYTHING and I am still having problems. My last resort is a factory restore. Before I go through all that I just wanted to know if someone else had problems with over heating and did the factory restore and it helped.
    Thanks!
    08-28-2013 08:51 AM
  2. Darnell0216's Avatar
    Did your phone receive the Apps2SD update? Most of the S4's that get it experience the overheating and/or battery drain and have the best results after resetting the Google account or factory resetting the whole phone. If you haven't received the update, continue looking for other possible causes before you resort to that.
    08-28-2013 09:37 AM
  3. velocitysc43's Avatar
    How can I tell if it received the Apps2SD update?
    08-28-2013 10:06 AM
  4. Jeremy_Collinsworth's Avatar
    This is due to Samsung having a really high clock speed (clocked at 1.9 ghz max). Personally, I like it. But yeah it will heat up the phone. Since I have all my devices rooted, I just lower the clock speed down and then raise it when I need the extra power. For you however, a factory reset should help. First though, delete and re add your Google account because the issue seems to be improved when people do that
    08-28-2013 10:10 AM
  5. velocitysc43's Avatar
    Thank you! I'll try deleting my Google account & see how that goes.
    08-28-2013 10:29 AM
  6. Darnell0216's Avatar
    If you received a firmware update that allows you to move apps to your SD card, you've got it.
    08-28-2013 11:51 AM
  1. What is this ? Please help .
    By sameer kapoor in forum Google Nexus 4
    Last Post: 08-30-2013, 03:39 AM
  2. I just got a free Chromecast with my Surface pro at Best Buy
    By FaisDogg in forum Google Chromecast
    Last Post: 08-29-2013, 04:02 PM
  3. I have a MetroPCS LG Motion 4G LTE...HELP!!!!!
    By Marlena_Rose in forum Android 4.0 Ice Cream Sandwich
    Last Post: 08-29-2013, 12:20 AM
  4. Trouble with syncing to Google Photos in stock gallery app
    By imthekingbk in forum Moto X (2013)
    Last Post: 08-28-2013, 08:46 PM
  5. Help help help
    By Jack Jerram in forum ASUS Fonepad
    Last Post: 08-28-2013, 01:38 PM
