1. Edible Walrus's Avatar
    My S4 gets quite warm. Just now hadn't played Real Racing 3 for more than three minutes when it got quite warm on the screen and back casing near camera. I don't want to damage my phone, but is this at all normal? my iPod touch did this occasionally, but doesn't seem to take much to get this quite warm
    EDIT: Total play time is actually about eleven minutes
    EDIT: Tried again, turned off S Beam, GPS, Smart Stay, Air Gesture etc, but left WiFi on and it seemed better. Case temperature didn't seem as hot, screen was still warm and played for about 20 minutes, used about 10% of battery rather than 20 or 30% like yesterday
    Here's my usage vs temperature
    Heat :(-2013-09-03150219_zpsf7d0bdc4.png
    09-01-2013 06:32 PM
  2. Golfdriver97's Avatar
    The game may be a little more than the S3 can handle.
    09-01-2013 06:36 PM
  3. Edible Walrus's Avatar
    Total play time was about 11 minutes and it's the S4
    09-01-2013 06:41 PM
  4. josiahlikesminecraft's Avatar
    Its pretty normal since its plastic it makes it feel a lot warmer than you iPod.
    Posted via Samsung S3
    09-01-2013 06:47 PM
  5. Edible Walrus's Avatar
    What is the point in ramming all that power in there if it's just going to get so hot after 10 minutes. Screen and back were 37 Celsius
    09-01-2013 07:51 PM
  6. josiahlikesminecraft's Avatar
    I'm not sure.
    09-01-2013 09:19 PM
  7. planoman's Avatar
    Quad cores are going. 37 C (98.6 F) is nothing. It is hotter than that outside in Dallas right now.
    Just have fun gaming the S4 can take it.
    Sent from my GT-I9505G
    09-01-2013 09:31 PM
  8. asanatheist's Avatar
    You should be fine playing games on it. I recommend turning down the screen brightness to about 50% or less.
    I've done 2 hours straight of dungeon hunter... not sure how I managed that.
    srkmagnus likes this.
    09-01-2013 09:35 PM
  9. srkmagnus's Avatar
    I was about to recommend lowering the screen brightness and doing what you can to keep power low. I wouldn't worry too much though - the S4 can handle the betting. It'll take more than that to mess it up.
    Sent from my SPH-D710 using Tapatalk 2
    09-01-2013 09:41 PM
  10. asanatheist's Avatar
    Last 3 days have been 100F+ weather near Dallas. Won't do much at all to the smartphone.
    09-01-2013 11:30 PM
  11. Edible Walrus's Avatar
    It was probably hotter when I was actually playing, can't say for sure since I had to leave Real Racing 3 to check
    Maybe heat is normal for phones now. This is my first smartphone and first phone with any real power so it's completely new to me. I did have Play Store still open though and Air Gesture, Smart Pause, Air View, Smart Stay, GPS, WiFi and 1 or 2 other things on when I booted RR3. I noticed:
    Real Racing 3: Made my phone the hottest, screen even heated up. Took about 11 minutes or so to get here with all the other stuff above running
    Iron Man 3: Second hottest. I'm not sure if the screen got warm
    Temple Run 2: Mild/barely warm
    Extended multi tasking: Eventually got warm
    Extended use doing phone like tasks: No heat
    Think I gamed for a total of 30 to 40 minutes and used about 30% battery doing so. So, it's probably just load
    09-02-2013 04:20 AM
  12. asanatheist's Avatar
    Almost forgot, also becareful when gaming and charging your phone.
    This goes for just about every smartphone though. From the Iphone 4S to the 5, to the HTC One, to Moto X.
    All of them got warm when charging, and got quite hot if you gamed while charging.
    09-02-2013 09:35 AM
  13. Topgonzo's Avatar
    Mine gets to 138. I guess all phones get hot but I've been wondering what is the threshold before there could be damage?
    Sent from my HTC One using Tapatalk 4 Beta
    09-02-2013 09:49 AM
  14. Edible Walrus's Avatar
    Mine doesn't heat up when charging, just when gaming. Turning off the extra stuff seemed to help a bit, even though antivirus said temperature was about the same (case didn't feel as hot though)
    09-02-2013 09:53 AM
  15. Aaron Watson's Avatar
    I heard that early batches of the s4 get hot but the new ones dont.
    09-02-2013 01:13 PM
  16. marrzie's Avatar
    The screen temp was the #1 reason I had to return my S4. It got too uncomfortable to play games. The area on back around the camera got warm but the screen was what really bothered me since I cant slap a case on the screen to help shield from the heat. Hope the note 2 does not have this issue.
    09-02-2013 01:25 PM
  17. Almeuit's Avatar
    Games will heat up the phone. No matter what setting you have on or off..
    It is like a PC. My video cards idle at 40-42 C. I start a game? Within 2-3 minutes they can jump to 80-85 C. This is due to the power increasing in he cards as they ramp from an idle mode to a full 3d ready mode.
    Sent from my T-Mobile HTC One using AC Forums.
    09-03-2013 08:19 AM
  18. Edible Walrus's Avatar
    What are the normal operating temps for this phone anyway? Mine idles at 27 C and reaches 37 - 38 when I play RR3
    EDIT: Here's my GSAM graph if that helps anybody
    09-03-2013 09:55 AM
  19. gollum18's Avatar
    Accepatable operating range for a smartphone CPU is around 70-120f. There is no fan and there is no heatsink to dissipate the heat, it's just a chip sitting on a board, with no ventilation. And its very possible that running the device at a high enough temperature for a long enough amount of time could actually cause your chips to become desoldered.
    Sent from my SPH-L710 using Tapatalk 2
    09-03-2013 10:44 AM
  1. strange noises and heat
    By uselessChiP in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-06-2013, 08:06 AM
  2. Phone heating up.
    By jc0187 in forum Samsung Galaxy S4
    Last Post: 08-28-2013, 04:16 PM
  3. Will a factory restore help with over heating?
    By velocitysc43 in forum Samsung Galaxy S4
    Last Post: 08-28-2013, 11:51 AM
  4. Google Maps heated my phone up
    By DoubleSixx in forum Verizon Samsung Galaxy S4
    Last Post: 08-25-2013, 01:15 PM
  5. Wireless Charging S4, what's normal heat level?
    By exempli_gratia in forum Verizon Samsung Galaxy S4
    Last Post: 08-24-2013, 07:08 PM
