Not Auto-Connecting to Wifi
I've been having this problem with my S4. When I leave my house (e.g. Leave my home wifi) and come back, my phone won't auto-connect to it. I have to pull down the notification bar and hit tab to configure wifi or whatever, and once I click that it connects. I didn't change anything from when it was working (as far as tasker goes and such). Anyone have any ideas?
Re: Not Auto-Connecting to Wifi
Bump. Anyone else been experiencing this?
Ive been having exactly the same problem so any answers would be greatly appreciated!
I'm glad I'm the only one with this problem. I really hope someone can help figure out a solution.
You are not the only one... This is happening to me also. Waiting on the Guru's to reply! COM'ON!
Posted via Android Central App using my awesome S4!
Originally Posted by
thornesone You are not the only one... This is happening to me also. Waiting on the Guru's to reply! COM'ON!
I guess this was an update or something, then. I'm pretty sure it started happening after I had some sort of update. I'm on Verizon by the way.
I contacted Samsung support and they told me to do a soft reset. If that doesn't work, they said restore my phone to factory settings. I'm holding off on that... lol.
I believe this started after the last Verizon update. Thanks Big Red... not!
thornesone I believe this started after the last Verizon update. Thanks Big Red... not!
Yup, that's when it started happening to me.
I can't find anything on Google about this, though! Arghhh!
I started a thread on this topic in the Verizon section. Please leave a comment there so Verizon gets the message they have an issue.
