First I apologize for taking so long to reply, I have a good reason
I fell through a large hole and broke my left leg in 3 places Tibea twice and Fibea once on the 30th. Just got out of the hospital last night.
Every router config page is different mahler9. But 9 times out of 10 you will find the wireless password on the same page as the SSID just usually further down, but to a novice it can be confusing.
Usually most routers wireless encryption are set to "WPA2-PSK [AES]" Then below that selection you should have the option to choose a "Pass Phrase" this can be anything your heart desires.
8-63 characters. It may be blocked out with stars, and even have a check box to SHOW PASSCODE or PHRASE.
You want to change that to something you prefer and then click SAVE SETTINGS or OK or whatever option you have to save what you have done.
Hope that helps. If not I am sure if you gave Verizon a quick shout they could tell you exactly where that is and how to get to it.
Please let me know if that all worked out for you
