1. Alaa Masoud1's Avatar
    hello
    bought mine 2 mounth ago and just before two days my phone start acting strange , like when its charged as example 70 or 80 or 50% it suddenly shut off and restart . after restart the battery percentage show battery level of 0% and it goes off because battery low , but i know it has power inside
    some times it stay like that and back to work , other times i need to plug it in the charger and once i did , it show the real percentage it was had before
    im sure some of you face this problem , is it the phone hardware problem or is it the battery ?
    also before this problem happen i was always amazed how fast my charger is , its the original galaxy s4 charger but the charging time are super fast
    like it need one hour to go 100% from zero% and for a 2600mah battery thats a real good thing
    so i guess it has something to do with my problem
    thanks
    09-10-2013 07:41 PM
  2. Darnell0216's Avatar
    Place your battery on a table or other flat surface. Push down on one corner and see if you can spin it. If it spins, it's starting to swell and the battery is bad.
    09-10-2013 07:53 PM
  1. samsung galaxy s3 fails on moving files from phone to sd card!
    By steveazusa in forum Samsung Galaxy S3
    Last Post: 08-27-2016, 01:03 PM
  2. Facebook Wakelock Problem
    By abbiesweetheart in forum Samsung Galaxy S4
    Last Post: 10-09-2013, 01:40 PM
  3. Adding more fonts to S4
    By UFRanger in forum General Help and How To
    Last Post: 09-12-2013, 05:26 PM
  4. Volume Problem: Glitch or Safety Setting?
    By Maddog121806 in forum Motorola Droid MAXX
    Last Post: 09-11-2013, 03:47 PM
