Screen does not turn off during call
kjmff5
5
New to the forum. Just grabbed a S4. When I make a call, the screen does not turn off. I know the proximity sensor works because Air gesture works, and I tried *#0*# with no cover the proximity is 0 with ADC of 3-5, then when I cover it the screen turns green with a proximity of 1 and ADC of 255. Is this a software issue now? Also under settings->my device->call->"Turn off screen during calls" is checked. The screen turns off after 30 seconds but thats because that is the time limit I set it as. I want it to turn off when I bring it to my face so I dont hit buttons on accident.
Thanks!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Welcome to Android Central! You're right, that shouldn't happen. Did you buy it new or used? If used, did you do a factory wipe, or are there apps from the previous owner still installed? Check to make sure there aren't any 3rd party apps that might be intended to prevent the screen from turning off.
kjmff5
5
Thank you for replying! Well somehow it fixed itself! I did absolutely nothing different. FYI I bought this phone new from amazon. I dont think I loaded it with any apps that should keep the screen on. I am so confused why randomly it starts working. Oh well life's great mysteries
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Glad it's working again, but keep trying to reproduce this problem. If it happens again, I would recommend bringing it back for an exchange, since you just got it. Better to do so now than in a few months, when you'll get more hassles for trying to exchange it.
kjmff5
5
Speaking of exchanged, that' something I do not want to deal with. I already had to swap out my phone once for a defective screen. Is there any option to make back up and restore as smooth as iPhones?
planeboy
