1. bruizer31's Avatar
    When I am at home my phone connects to my wifi but it is not working as nothing will load...as soon as it switches over to mobile data it works just fine. Any suggestions
    09-14-2013 09:37 PM
  2. B. Diddy's Avatar
    A few things to try:
    -Reboot the router by unplugging the power, waiting 10 seconds, then plugging it back in and waiting another 20-30 seconds for the connection to reestablish.
    -On your phone, go to Settings/Wireless & Networks/Wifi, select your network, and select "Forget." Then reconnect to it again.
    -Adjust your router's security settings. You probably have to refer to your router's manual to learn how to do this. Try changing WPA to WEP or vice-versa, or the password format from TKIP to AES or vice-versa. As a last resort, try turning off all router security to see if that's blocking things.
    Badxz Aleitheia likes this.
    09-14-2013 11:34 PM
  3. Rob Verhagen's Avatar
    I have put together a work around fix. Let me know if this helps you out
    Phone fixes dot com
    11-18-2013 02:11 PM
  1. GN 2 to GN3 Using Samsung Smart Switch App?
    By gspam1 in forum Samsung Galaxy Note 3
    Last Post: 09-17-2013, 07:52 PM
  2. Verizon HTC One experiencing major problems
    By Cayderayd in forum HTC One M7
    Last Post: 09-16-2013, 11:26 PM
  3. Buying galaxy s4 on walmart online store
    By BTL94 in forum Samsung Galaxy S4
    Last Post: 09-14-2013, 09:24 PM
  4. sprint gs3 4.1.2 wifi tethering ..here we go again
    By Leonce Bienville IV in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-14-2013, 07:28 PM
  5. Replies: 0
    Last Post: 09-14-2013, 05:57 PM
