G GL99 New member Sep 16, 2013 2 0 0 Visit site Sep 16, 2013 #1 hello guys, i'm new here. . need help about media server in my S4. here a picture : already restart and server media still appear on battery usage. what should i do? thank you very much !!
S STSVA Well-known member Aug 7, 2013 619 0 0 Visit site Sep 16, 2013 #2 Take a look here http://forums.androidcentral.com/samsung-galaxy-s4/310753-s4-media-server-drains-battery.html#post3037187. You can see which apps are using the media server, then change settings in those apps or disable them to decrease use.
G GL99 New member Sep 16, 2013 2 0 0 Visit site Sep 23, 2013 #3 STSVA said: Take a look here http://forums.androidcentral.com/samsung-galaxy-s4/310753-s4-media-server-drains-battery.html#post3037187. You can see which apps are using the media server, then change settings in those apps or disable them to decrease use. Click to expand... thanks for the reply today this problem appears again. when i touch media server. there no one apps running. it is a bug? but if i shut down the phone in 5 mins, then start the phone again, the problem dissapear. very confused with this.
