1. ytsejam85's Avatar
    There are a few apps that are allowed in the multi Window drawer. I can't find any way to add more to this fixed list of apps. Can it be done without rooting the device?
    09-20-2013 02:32 PM
  2. HPferoxCraft's Avatar
    There's links on here to more alternative apps that use it, you'll have to search for it, but to add whatever you want you need root.
    Edit: here you go
    http://forums.androidcentral.com/sam...ml#post2637851
    Posted using the AC app
    09-20-2013 02:35 PM
  3. SpookDroid's Avatar
    All apps that are officially compatible will be automatically loaded into the list, either into the 'main' drawer or to the hidden one, accessible via the 'Edit' button which allows you to show or hide apps from the main drawer.
    However, the list is still small. If you root and apply a hack, you can use multiWindow with virtually any app, but there are the inherent risks of rooting and also the expected bugginess of using an app that is not oficially supported in that mode. If the trade-off is worth it, it's up to you to decide.
    09-20-2013 04:28 PM
  4. ytsejam85's Avatar
    Thanks guys. Very helpful. I was already thinking of rooting my phone. I did on my htc evo and everything was okay. I'll check out that link you put up. Thanks
    09-21-2013 12:26 AM
  5. lynn5955's Avatar
    i dont think u can add more
    09-21-2013 01:56 AM
  6. prozacfield's Avatar
    Root, install Xposed Framework then Wanam Xposed module, it will allow you to add any app to Multi Window along with many other cool features. But think twice if you have i9500, there's no way to reset flash counter on this model once you root it which means your warranty is void permanently.
    09-21-2013 03:01 AM
  7. HPferoxCraft's Avatar
    You don't necessarily need Xposed or wanam to do it. There's a Multi Window Manager (root) app in the playstore.
    09-21-2013 10:57 AM
  8. Vijayaraj R Nair's Avatar
    i use note3 neo android phone, i have more than 5000 contacts in my phone and i use to give each and every detail on a contact like name, nick name, company name, position, photograph, emails, other phones, detail address, note about when met initially, birthday etc about each person. last 2 days before i happen to sync my contacts with gmail. now i find those contacts which had photograph an details are not there. people calling me shows only his mobile number. contact is not there on my list of contacts. the photos i took and saved for contacts too changed and for some other small photos are coming. please help 9037162219
    08-16-2015 11:44 PM
  9. hkbladelawhk's Avatar
    MW Manager requires Xposed.
    08-18-2015 03:55 PM
  10. ittiandro's Avatar
    I have a Samsung Galaxy 4 tablet with XMultiwindow and Exposed Installer installed for some time . It always worked. The tablet IS rooted and usually I can add apps with no problem by clicking on the " Open Side bar " tab.
    I wanted to add another app I just downloaded ( UB Reader) but when I click to open the ADD list, nothing happens: the XMultiwindow app exits and I get back to the Home screen of the tablet.
    As to the apps already in the XMulti Window side bar , if I try to open two apps at the same time with reduced size floating screens, only one gets opened, full screen. The other one is bumped off..No way to have two floating reduced screens like before
    Any help?
    Thanks
    Ittiandro
    09-27-2017 02:43 PM
  1. How can they sell SIM cards so cheap?
    By Jon Sid in forum General Carrier Discussion
    Last Post: 02-01-2014, 09:12 AM
  2. Notification bar is to busy.
    By Bloodthirsty in forum LG G2
    Last Post: 12-04-2013, 10:32 AM
  3. S4A How many water sensors?
    By kwando303 in forum Samsung Galaxy S4 Active
    Last Post: 09-27-2013, 03:31 AM
  4. Where is the quickview case????
    By marky_yo in forum LG G2
    Last Post: 09-26-2013, 07:54 PM
  5. How do I get the YouTube app to play full screen landscape mode?
    By cussy182 in forum Google Nexus 7 Tablet (2012)
    Last Post: 09-20-2013, 03:25 PM
