1. gkitf16's Avatar
    I can't get the camera ISO to remain set after taking a picture. Is there a way to force this until you want it back at the default Auto setting? Wastes a huge amount of time and ruins great shots that blur because the shutter was too slow in less than bright light when flash is not needed.
    09-21-2013 01:08 AM
  2. Haalcyon's Avatar
    Welcome to Android Central! I haven't seen that in the camera settings but it would, indeeed, be useful.
    09-21-2013 05:46 AM
  3. STSVA's Avatar
    It doesn't look like there's a way to do it except by keeping the camera app active. You can leave the app active, use the home button to put it in the background, then use other apps and return to the camera when you need it. I did that while editing this post, and the camera is still on ISO 800 where I left it.
    09-21-2013 03:18 PM
  4. Haalcyon's Avatar
    A firmware update could "fix" that. We can only hope...but I wonder how many folks are looking for that. Most just leave ISO on auto and never change it, I'm sure.
    09-21-2013 04:41 PM
  5. gkitf16's Avatar
    Unfortunately it hobbles the camera severely, limiting its usefulness. Why even have the feature if it isn't user-friendly? By the time I quit fooling with a setting, the photo opp is often lost. People aren't going to stand around waiting for you to fix something and just take the picture.
    09-21-2013 06:23 PM
  6. gkitf16's Avatar
    I'd like to see the camera retain the user-chosen setting, along with displaying the ISO number on-screen along with the shutter speed/aperture, depending on what Mode you're in. Could be switched on or off, just helps to have better info on-screen.
    09-22-2013 06:29 PM
  7. STSVA's Avatar
    I'd like a live RGB histrogram too, but I'm not holding my breath waiting for them to add it.
    09-22-2013 07:01 PM
  8. gkitf16's Avatar
    With such a tiny screen, that's a little overkill, just basic info on display w/o having to peck into a menu first would suffice
    09-24-2013 06:28 AM
  1. Galaxy S4 camera ISO setting
    By gkitf16 in forum Samsung Cameras
    Last Post: 11-19-2014, 02:27 PM
  2. GOOGLE WALLET on VZW S4???
    By OverLordOfYou in forum Samsung Galaxy S4
    Last Post: 12-08-2013, 07:03 AM
  3. galaxy s4 stolen
    By jsbcarman in forum Samsung Galaxy S4
    Last Post: 10-01-2013, 10:53 AM
  4. Sprint Samsung Galaxy S4 - FS/FT - Rooted & SIM Unlocked
    By beathookup in forum Marketplace Archive
    Last Post: 09-27-2013, 03:38 PM
  5. Some motion controls not working.
    By mtech5 in forum AT&T Galaxy Note 2
    Last Post: 09-20-2013, 09:22 PM
