1. AM759's Avatar
    On my S4 there is a power savings mode. I've used it a few times and im not sure if it's worth using. Could somebody tell me if it makes a big difference or if it not. Also it says that it limits the performance of the cpu and I was wondering how much. Thanks for the help.
    09-22-2013 09:47 AM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    Honestly, I am not sure how much that can save. I would guess a fair amount, by just limiting performance of the CPU, but I don't know exactly how much. Samsung used to have a power save feature that would let you customize screen brightness, turning off radios, and a couple other things, but for some reason got rid of that and put the current one in it's place. I liked the older one better.
    AM759 likes this.
    09-22-2013 10:02 AM
  3. Haalcyon's Avatar
    Welcome to Android Central! On my S4 and Note 8.0 I have Power Save enabled and while it limits max CPU frequency it hasn't hurt performance for the way I use gadgets. I'm sure how much extra battery time it has gotten me, if any, but I'd say try it and see if it affect performance or battery life in a way you notice.
    from my Sony Xperia Tablet Z or XTZ or "Ecstasy"
    09-22-2013 10:52 AM
  4. AM759's Avatar
    Thanks for the relpy. Too bad it doesnt still have those features.
    09-22-2013 11:03 AM
  5. AM759's Avatar
    I think I might try a day with it on to see how much it helps.
    09-22-2013 11:08 AM
  6. Haalcyon's Avatar
    You may want to check out Juice Defender too. It can "intelligently" enable/disable radios which may help eek out a few more minutes of battery life.
    09-22-2013 11:08 AM
  7. STSVA's Avatar
    I use Juice Defender and have been happy with it. I'm using the Lux app to control brightness rather than Juice Defender, however.
    AM759 likes this.
    09-22-2013 11:18 AM
  8. AM759's Avatar
    Thanks. I'll try that.
    09-22-2013 11:26 AM
  1. Will the Chrome browser get a Reader mode in KitKat?
    By saintforlife in forum Android 4.4 KitKat
    Last Post: 10-21-2013, 12:08 PM
  2. Samsung Gear Smartwatch sans phone
    By JJDubs in forum Samsung Galaxy Gear
    Last Post: 10-09-2013, 07:31 AM
  3. Failed to enter recovery mode.
    By 1983parrothead in forum Verizon Samsung Galaxy S4
    Last Post: 09-22-2013, 07:22 PM
  4. Micro SD Card for Samsung Galaxy SIII
    By Jelfer in forum General Help and How To
    Last Post: 09-22-2013, 12:44 AM
  5. Samsung Galaxy S4 (Sprint SPH-L720) - Custom ROM WiFi Not Working
    By mightymo77 in forum General Help and How To
    Last Post: 09-21-2013, 04:14 PM
