1. neel69's Avatar
    Just few minutes back it was displaying all the things like display, music, etc using the battery. Now its just the Android OS? Restarted the device twice, but in vain! Help appreciated. Thanks.
    Query regarding display of options under the "battery" settings-screenshot_2013-09-23-14-43-45.jpg
    Query regarding display of options under the "battery" settings-screenshot_2013-09-23-14-44-01.jpg
    09-23-2013 04:22 AM
  2. meyerweb#CB's Avatar
    I"ve seen this happen a couple of times when a device encountered an error and restarted on it's own. If you charge it to 100%, then unplug, all the stats should reset and get back to normal.
    09-23-2013 08:41 AM
  3. garublador's Avatar
    Mine did that for 2 days and then went back to normal. I don't remember if GSam gave good readings at the time or not. You can try an app like that to see if it give accurate readings.
    09-23-2013 09:11 AM
  4. neel69's Avatar
    I did a factory reset. Now all back to normal.
    Thanks anyways!
    09-23-2013 12:10 PM
  1. Who here is going to get the wireless charging S view cover?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 09-29-2013, 01:56 PM
  2. How to clean the display without turning it off?
    By Steve Swift in forum Samsung Galaxy S4
    Last Post: 09-24-2013, 01:19 AM
  3. Set a Notification at a specific Time
    By maxtacchetti in forum Software Development and Hacking
    Last Post: 09-23-2013, 04:23 AM
