1. Doublelime's Avatar
    I've had my galaxy s4 for about 2 months now and the battery is terrible. I have everything turned off including location services. My screen brightness is minimum. I keep my wifi off and turn 3g on manually. The only thing i have turned on is screen rotation and silent. I have Google now turned off. I also have the lights for capacitive buttons turned off including vibration when i use them.
    I've Googled how to imprudent battery life about 10 times and I've done absolutely everything.
    I have juice defender, Wakelock detector, battery doctor installed.
    I literally only use nova launcher prime on my phone.
    I don't know what to do now because I'm only getting 2 hours 30 mins screen life
    09-23-2013 03:10 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sounds like you've done a lot. Have you considered calling Samsung to see if you could send the phone in under warranty?
    09-23-2013 03:23 PM
  3. Doublelime's Avatar
    I haven't called them yet but won't they offer a replacement/ repair? I don't want to pay them 50 for postage costs and I also have a 25 screen protector on my phone. I don't know what to do because this is my first proper android.
    09-23-2013 03:52 PM
  4. B. Diddy's Avatar
    Is the cell signal good where you usually use your phone? Poor signal can drain the battery.
    09-23-2013 06:16 PM
  5. Shadowtc's Avatar
    You could either have bad signal like diddy said or you could have a defective battery I get 24 hours on battery with moderate use
    Sent from my Nexus S 4G using Tapatalk 2
    09-23-2013 07:02 PM
  6. STSVA's Avatar
    What does Settings - More - Battery tell you is using up your battery?
    09-24-2013 07:54 AM
  1. Replies: 3
    Last Post: 09-25-2013, 10:52 AM
  2. What is wrong with my battery?
    By Androidprodigy in forum Verizon Galaxy S III
    Last Post: 09-23-2013, 08:58 PM
  3. Replies: 3
    Last Post: 09-23-2013, 12:10 PM
  4. Battery percentage on status bar disappeared
    By Marco Beri in forum Google Nexus 4
    Last Post: 09-23-2013, 08:39 AM
  5. Samsung international wifi problem
    By cupatea123 in forum Samsung Galaxy S3
    Last Post: 09-23-2013, 08:03 AM
