Originally Posted by
STSVA How about some more info. on what you've got your phone doing while you're "not using it" - for example, from your reference to email it sounds like you have some kind of data connection going all the time. Is this over-the-air or wifi? Anything else going on behind the scenes?
sorry. for the most part my phone sits on my desk all day. i do not have the wifi turned on.
today i am at 70% battery at 10:30. I probably unplugged at around 7. of the 30% battery that has been used android core apps has used 39% of it. it says:
wakeclock detail = *backup* 0.0s (1)
included packages = contacts
included processes = com.sec.android.provider.logsprovider
android.process.acore
com.android.contacts
