1. go4christ's Avatar
    Every couple of days, despite the number of times I've cleared this notification, my phone remind me that it can be used as a remote control device. Is there anyway I can prevent this ad from popping up in my notifications?
    09-30-2013 10:11 PM
  2. Rashawn29's Avatar
    The only way is to go through the setup.
    Posted via Nexus 10 Android Central App
    09-30-2013 10:20 PM
  3. go4christ's Avatar
    Do you know where in the setup specifically I need to make changes?
    09-30-2013 10:23 PM
