1. scottgoodhill's Avatar
    Hi folks,
    Posted yesterday about having battery issues (slow to charge and runs out very quickly). After looking into my phone a bit more and a chance discussion with a guy with an S4 yesterday I noticed that my screen is consuming an awful lot of power compared to his even though I have my brightness now on the lowest setting and all "Smart Screen" features turned off. His screen was using only 5% of the battery power whilst my screen is apparently using 49%. I was wondering if anyone knew of any obvious fixes to this or has encountered an issue like this as well? Considered buying a new battery yesterday but if it's related to the screen then could it possibly be a software problem? Any ideas would be helpful!
    Cheers gang.
    10-01-2013 05:37 AM
  2. charlee08's Avatar
    That's just your screen on time.
    If you want to conserve battery life, turn off all location services in Google settings, kill your recently used apps, and under app settings - make sure that there isn't something running that you don't use. Adjusting your screen brightness to a low setting will definitely help as well.
    If you're a heavy user then you aren't going to get more than 6-8 hours anyway. But those above tips should help you.
    10-01-2013 05:51 AM
  3. Haalcyon's Avatar
    My battery shows even higher usage but seems to be fine. Can you post a screenshot of your battery usage?
    10-01-2013 05:53 AM
  4. Almeuit's Avatar
    Screen should always take the most battery... Unless you never use your phone.
    Sent from my T-Mobile HTC One using AC Forums.
    ladyhaly likes this.
    10-01-2013 06:37 AM
  5. Haalcyon's Avatar
    This
    10-01-2013 08:41 AM
  6. ladyhaly's Avatar
    Here is mine. I believe yours is pretty normal.
    We differ in the ways we use our phones... For one thing, I always have Mobile Data, GPS, and SmartStay on. I also always have my hands on my phone. There is no time that this isn't by my side.
    Someone who uses the phone less than me... For example, someone who isn't as app crazed and just likes to look once in a while to send a text or call would have a longer battery life than me.
    Sent from my GT-I9505 using Tapatalk 4
    10-01-2013 08:59 AM
  7. lakay2013's Avatar
    I'm having the same issue with my S4. I bought it new 4 days ago and have only made a 18 minute call, and sent a few texts today and it shows that my battery is now on 62%. I killed all my apps and made sure smart stay, air view, and the other options are off. I can send a few texts and the battery life drops 2% as I send them. I'm not sure what the deal is.
    10-01-2013 09:37 AM
  8. Haalcyon's Avatar
    What carrier? If your phone is looking for signal that'll eat up battery life quick, as will GPS and bluetooth.
    10-01-2013 09:42 AM
  9. lakay2013's Avatar
    Verizon. I'm new to Android, I just switched from iPhone. I've been connected to wifi all morning. It shows that my screen is taking up 52% of the battery and I have it on the lowest resolution it will go.
    10-01-2013 09:46 AM
  10. Haalcyon's Avatar
    Perhaps you can post some screenshots of your battery life (power+home to screen capture)?
    10-01-2013 09:49 AM
  11. lakay2013's Avatar
    10-01-2013 09:56 AM
  12. lakay2013's Avatar
    That is my battery life without getting on any apps at all since 6:00 AM. I have only made 1 call, a few texts, and checked my email a couple times.
    10-01-2013 09:59 AM
  13. STSVA's Avatar
    It looks like the screen was on a fair amount of the time - that will use up battery faster than just about anything else.
    10-01-2013 10:04 AM
  14. redrover69's Avatar
    Anyone using easy battery saver???
    or the snapdragon ap?
    Do those apps really work????
    10-01-2013 10:47 AM
  15. starbuckk's Avatar
    Percentage of use really is not that helpful. Get an app called Better Battery Stats. Your phone may have a wake lock running keeping it from sleeping when not in use. I found whenever my battery starts dying fast that a kernel wake lock called msm_camera was the culprit. Only restarting the phone makes it go away.
    Sent from the tiny keyboard on my S4
    10-01-2013 10:57 AM
  16. Haalcyon's Avatar
    I'm only using Juice Defender on my S IV. I think it may help a tiny bit by managing the radios when I'm not using the device.
    from my Sony XTZ
    10-01-2013 10:59 AM
  17. Almeuit's Avatar
    10-01-2013 12:24 PM
  18. STSVA's Avatar
    I've been using Juice Defender, and think it does help. Right now I'm trying out Snapdragon Battery Guru, which some people think is great. I haven't used it long enough to see what it can do.
    10-01-2013 01:14 PM
  19. UJ95x's Avatar
    Damn, are you turning off mobile data and all of the features off? The best I have gotten is about 4 and a half hours of screen time and had 1 day and 2 hours without charging. How are you getting 5 and a half hours with 2 days off the charger?
    10-01-2013 04:19 PM
  20. Galaxia's Avatar
    Stupid question... What happens when you turn mobile data off? I always thought that was like turning airplane mode off? I'm always in wifi but wanna receive calls and texts. How would turning off mobile data affect that?
    Sent from my VZW S4
    10-01-2013 04:32 PM
  21. garublador's Avatar
    Sent from my VZW S4
    My understanding is that you'll get just about everything except for MMS (picture and video texts).
    10-01-2013 04:47 PM
  22. Shanicenicolle's Avatar
    How the hell do you get 2 days?
    Sent from my *PURPLE* Galaxy S4
    10-01-2013 05:11 PM
  23. Haalcyon's Avatar
    Juice Defender?
    fromy my Sony XTZ via Tapatalk IV
    STSVA likes this.
    10-01-2013 05:46 PM
  24. Shanicenicolle's Avatar
    Juice Defender?
    Lol I need to try this
    10-01-2013 06:03 PM
  25. Haalcyon's Avatar
    It's good stuff.
    10-01-2013 06:22 PM
  1. Replies: 24
    Last Post: 07-09-2017, 12:28 PM
  2. HTC One HDMI Screen Scaling / Overscan Possible?
    By sterod in forum HTC One M7
    Last Post: 04-05-2014, 04:54 PM
  3. Feel of the black versions back and disassembly of Note 3 (Video)
    By MannyZ28 in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 10:35 PM
  4. Flexible screen, useful or gimick
    By dss2000 in forum Samsung Galaxy Note 3
    Last Post: 10-02-2013, 01:20 PM
