1. Liam Smart's Avatar
    Hi everyone,
    I'm having a problem with the front camera on my S4.
    Before capturing a picture, the quality looks normal. After capturing a photo, it's as if a soft blur effect is automatically added, drastically reducing the quality.
    I've made sure the lens is clean and there is no plastic covering the lens. The same happens with Instagram... quality looks fine before capturing and then the same awful result afterwards. Interestingly, Snapchat captures what is on the screen and doesn't apply any after effect.
    Can anyone help me?
    10-01-2013 09:45 AM
  2. STSVA's Avatar
    Hi everyone,
    Can anyone help me?
    Are you sure it's not motion blur from slight movement of the phone when you take the picture?
    Liam Smart likes this.
    10-01-2013 10:15 AM
  3. Liam Smart's Avatar
    That's what I was thinking, but if I can take a normal photo with Snapchat for example, then that can't be right?
    It seems to be when the light is generally low, the phone tries to compensate. All settings that would allow this to happen have been switched off but I'm still at a loss...
    10-01-2013 10:33 AM
  4. STSVA's Avatar
    Different camera apps may have different algorithms for setting the shutter speed under any given lighting conditions. I've noticed that the stock S4 camera seems to consistently use a slow shutter speed except in very bright light. Have you checked the details for the JPEG images from the stock camera and Snapchat to see if there's a difference in shutter speed? I certainly don't know if this is the answer, but I think it could be.
    10-01-2013 12:07 PM
  5. Liam Smart's Avatar
    That sounds right to me, Stsva.
    Is there any way I can change the shutter speed of the stock camera or will I just have to grin and put up with it? It's such a shame seen as I've just only upgraded from S2 and never had a problem with that phone!
    10-01-2013 12:12 PM
  6. STSVA's Avatar
    As far as I can tell, you can only control shutter speed indirectly, either through the shooting mode you select (e.g., sports mode will use a faster shutter speed than some of the others), or through your selection of ISO (e.g., a higher ISO will allow a faster shutter speed).
    10-01-2013 01:11 PM
  1. Advanced Issue - Very peculiar problem! Help sought.
    By AtomicMenace in forum AT&T Galaxy S III
    Last Post: 01-29-2015, 08:22 AM
  2. Camera help
    By panrrak96 in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-01-2013, 02:55 PM
  3. Camera, how do I use it?
    By conan1071 in forum Motorola Droid MAXX
    Last Post: 10-01-2013, 09:23 AM
  4. Camera app not working
    By Lorrie Whalen in forum Samsung Galaxy S3
    Last Post: 10-01-2013, 01:06 AM
  5. Replies: 0
    Last Post: 09-30-2013, 08:59 PM
