09-08-2016 06:41 PM
33 12
tools
  1. m733's Avatar
    Battery technology is still imperfect. Even if the screen shows 100%, it does not always mean the battery is charged physically 100%. My phone sometimes drop from 100% to around 90% in 10 minutes which is inaccurate even though I don't use the phone. The software is just trying to match the actual amount of battery by giving you number of % but no guarantee.
    02-04-2014 03:16 PM
  2. Prudz's Avatar
    I own Samsung S4 . when i charge it , after 10,15 mins it shows battery full notification but when i unplug and then plug it again then it shows charging .. i have to repeat it for several times if i dont then battery shows 5 % after 10 min of use ....
    Pls any one who know how to fix it ? Note : Battery is brand new
    I am also experiencing the same problem.I live in South Africa.This is so frustrating.
    02-16-2014 09:23 AM
  3. Manny Darabaner's Avatar
    Thanks guys,
    i have my S4 (1 years old)
    I have the same probelm. i bought new original battery and the phone keep drains. after 2-3 hrs work it comes to 15-14%
    I think that something might be wrong wrong with the phones CPU.
    who know how can i check it?
    06-29-2014 03:37 AM
  4. Paul Baronia's Avatar
    HELP! I don't know if my battery is broken or maybe my phone. It shows the sign that it's charging (the one with the lightning on the battery) but it remains 0% or 1%. I've tried several chargers and it's charging but the battery's still 0/1% I've charged it for more than an hour already and did the restart and remove battery method. What should I do?
    06-30-2014 01:53 PM
  5. Arham Ibrar's Avatar
    where did u got the battery from please tell i am also suffering from the same problem pleasetwll
    09-23-2014 04:20 AM
  6. Numan Sharf Ul Din's Avatar
    Guys i need help i got samsung gt i9505 when i remove the bettery it won,t turn on at all nothing happened not even charge then i have to charge with universal charger out of from phone i change the battery also but no thing happened it react same like that when it power on after 4 5 hours it works fine no problem at all what should i do
    03-02-2015 03:04 PM
  7. Aislynn Lampshire's Avatar
    its not the battery the phone just needs to be left alone not on the charger you can even leave the battery out it sorta of helps leave your phone alone for an hour or 2
    06-11-2015 01:33 PM
  8. S12s's Avatar
    I'm having the same problems exactly & cutting out during calls. So let me know if you find a fix please 😢
    09-08-2016 06:41 PM
33 12
  1. Replies: 12
    Last Post: 10-10-2013, 02:45 PM
  2. General compatibility question with Google Play on tablet
    By justanotherguy in forum General Help and How To
    Last Post: 10-03-2013, 11:05 PM
  3. Oficial Samsung Charger compatible with anker 5200mha battery?
    By Nuno Mota in forum Samsung Galaxy S4
    Last Post: 10-03-2013, 01:02 PM
  4. transfer all info from S4 to Note 3
    By gumbyr1 in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 11:52 AM
  5. Samsung Galaxy S3 not getting recharged!
    By Divig in forum Samsung Galaxy S3
    Last Post: 10-03-2013, 02:39 AM
