1. BirchBarlow's Avatar
    Ever since I got the phone several months ago the 4G speed has been noticeably slower than the Wifi but I never actually ran a speed test until today and this is what I got...
    7.41 Mbps up/5.45 Mbps down with 76 ms ping.
    Is it just me or does that seem really slow considering AT&T boasts the fastest LTE network? What speeds do you people typically get for 4G whether you're on AT&T or another carrier? I know it's not going to be as fast as Wifi as cellular internet hasn't yet caught up to cable, but still don't you think it should be faster than what I get?
    10-08-2013 08:55 PM
  2. UJ95x's Avatar
    I get 28 MBPS down and 12 up on my T-Mobile GS4. It depends on where you live more than on your carrier. If you're in a metropolitan area it could be a lot slower because so many people are on the network. 7 is still fast, only time you need 40+ is when you're downloading something big
    10-08-2013 09:07 PM
  3. Fuego's Avatar
    Chances are good that you're actually in a 4G LTE fringe area with those speeds and dropping back to 4G (non LTE). I'm in a good LTE area and tonight I'm getting 41ms pings w/ 24.6mbps down and 22.4 up. I've actually seen speeds up to 50% faster but I don't check that often
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
    10-09-2013 01:03 AM
  4. UJ95x's Avatar
    Repost
    10-09-2013 04:15 AM
  5. michaelboothe's Avatar
    I have a Samsung Skyrocket 4G/4G LTE. Until a few months ago, I didn't have LTE in my area. I was getting around 3 to 4 mbps speeds on 4G. LTE is now working in two cities about 30 miles from where I live. When in those cities, I get great speeds. However, in my town, I only get 2 mbps max on LTE. So, basically, I am using a faster technology and getting slower speeds. I can't find a way to go back to just 4G.
    10-09-2013 06:58 PM
  6. UJ95x's Avatar
    Go into your settings > connections > more networks > mobile networks amd select GSM/WCDMA only instead of LTE/GSM/WCDMA. You'll connect only to 4G even if the area has LTE
    10-12-2013 01:46 AM
  7. yensid05's Avatar
    Hello!! I am a happy owner of a Verizon Samsung 4G LTE Tablet. It is moving VERY slow. I have cleared the cache on everything, deleted several pictures, got rid of some app's, reformatted my SD Card, I even tried a factory reset and it continues to run slow. Does anyone have any suggestions as to how to correct this issue? And please try to dumb it for me!!! I'm computer illiterate!!!
    Thanks in advance,
    Yensid
    03-05-2016 11:16 PM
  8. Nowty Prince's Avatar
    Hello everyone i have 4g and my speed 1mbs up 180kbs down
    08-06-2016 05:33 AM
  9. Mohamed Gherab's Avatar
    hello Guys .....i tried internet acclerator .......and it works ....but just for few minutes but after that it became useless ......any solution ?
    11-26-2016 05:25 PM
  1. Is there an option to have the screen come on when you get a text?
    By MannyZ28 in forum Samsung Galaxy Note 3
    Last Post: 10-20-2013, 12:07 PM
  2. What I need to do before selling my Samsung Tab 2?
    By Redcatt77 in forum Samsung Galaxy Tab 2
    Last Post: 10-09-2013, 11:54 PM
  3. HP Chromebook 14" Gen 2 pricing is up
    By shiner#AC in forum Chromebooks
    Last Post: 10-09-2013, 06:57 PM
  4. Charging Note 3 in my truck
    By browetally in forum Samsung Galaxy Note 3
    Last Post: 10-09-2013, 11:25 AM
  5. is it possible to use the old Google maps
    By luzgemacht in forum HTC One M7
    Last Post: 10-09-2013, 08:03 AM
