10-10-2013 06:16 PM
30 12
tools
  1. HPferoxCraft's Avatar
    Just redo the process you did the 1st time when you ran it and it said 0.
    Restore your nandroid, run TA, if it says 0 plug it into your Pc and continue with the Odin process.
    UJ95x likes this.
    10-10-2013 02:03 PM
  2. UJ95x's Avatar
    I did it. Counter still at 1, binary still custom.
    Edit: Nevermind, forgot to run TA again. It's at 0 now and binary is official. Thanks
    HPferoxCraft likes this.
    10-10-2013 03:43 PM
  3. UJ95x's Avatar
    One last thing, is there anyway to check flash counts without root? So I can see if it stayed at 0 after unrooting.
    10-10-2013 05:24 PM
  4. HPferoxCraft's Avatar
    Under system settings ->more->about device->status, scroll all the way down and it'll say official.
    I believe that's correct.
    10-10-2013 05:42 PM
  5. UJ95x's Avatar
    And if the counter was at one it wouldn't say official right? Thanks, now unrooted and on stock firmware. Did it during my computer engineering class XD
    10-10-2013 06:16 PM
30 12
  1. Reinstalled Froyo 2.2 Stock - How do I get rid of the OTA update notification?!
    By DoomMunky in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 10-22-2013, 11:45 AM
  2. From Stock to CyanogenMod?
    By yacoubean in forum Verizon HTC One
    Last Post: 10-15-2013, 07:32 PM
  3. New firmware update for SM-N9005
    By Yathani in forum Samsung Galaxy Note 3
    Last Post: 10-12-2013, 07:05 AM
  4. Latest firmware compatible with Xperia Play?
    By ConstructTwelve in forum Sony Xperia Series
    Last Post: 10-07-2013, 06:30 PM
  5. T-Mobile Online & Pre-Orders Backordered but Stores have Stock!
    By DalTXJim in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 01:13 PM
