1. thomas9506's Avatar
    Hi I flashed cm and it was working fine for awhile then I woke up and I had lost my mobile data and ability to send and recieve texts.
    The apn settings are correct, Ive restarted the phone and pulled out the battery and sim. Reflashed stock and cm a bunch of times, factory reset a few times. But nothing seems to be working. I noticed in cm there was an option for ruimsim and nv but I could only select nv..
    I am now on rooted stock and the problem persists. So how do I fix it?
    10-11-2013 07:11 AM
  2. Almeuit's Avatar
    Pay your bill? Lol just kidding. How long has it been going on? What carrier? Could be possible that there is an outage.
    Sent from my T-Mobile Note 3 using AC Forums.
    10-11-2013 07:37 AM
  3. thomas9506's Avatar
    Its been maybe 3-4 days. Im with koodo and I looked into it and they say that theres no outages and everything should be running smooth.
    10-11-2013 07:41 AM
  1. Note 3 issues with 5ghz wifi?
    By Yellowfddriver in forum Samsung Galaxy Note 3
    Last Post: 05-10-2014, 10:37 AM
  2. Note 3 Sview cover with Nova Launcher
    By benski in forum Samsung Galaxy Note 3
    Last Post: 10-14-2013, 06:56 PM
  3. Using USB 3.0 cable to connect to PC?
    By TXGTOU in forum Samsung Galaxy Note 3
    Last Post: 10-11-2013, 11:40 PM
  4. For those that did in store pickup with VZW
    By Galaxia in forum Samsung Galaxy Note 3
    Last Post: 10-11-2013, 08:27 AM
  5. Replies: 0
    Last Post: 10-11-2013, 05:45 AM
