1. Jude Mathis's Avatar
    Hi, im new to samsung and android stuff and i want to ask a question regarding battery life.Why is that after 15 minutes my battery went from 100% to 97%.Is this normal? Coz i really haven't done anything besides browsing through the net.And my battery usage says that my screen is using the most battery with 78% usage.I don't quite know what's using up my battery that fast or is it normal? Have all the features turned of and my brightness lower.My phone is 2 weeks old btw.
    Thanks!
    10-11-2013 01:01 PM
  2. stramuzik's Avatar
    its normal in all android devices expect NOTES because it has a 3100mAH battery where as the s4 has a 2700mAH battery and even s4 has a AMOLED display and the screen consumes the power much
    10-11-2013 01:07 PM
  3. Jude Mathis's Avatar
    I see, thanks for the fast reply!
    10-11-2013 01:17 PM
  4. stramuzik's Avatar
    10-11-2013 01:23 PM
  5. hausjam's Avatar
    Same thing here. Its weird coming from an iPhone where you can use it for like half an hour and it still shows 100% . but I have always questioned the legitimacy of that.
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    10-12-2013 01:05 AM
  6. prozacfield's Avatar
    Thanks!
    Screen on + signal + browser itself + background services = battery going down. There's nothing to do with it, that's the way this OS works. If you want to know more, get Wakelock Detector and learn to use it, this way you can find what is eating your battery and maybe disable/get rid of it. Google Services is the main problem, poor signal is the second. If you have many widgets consider removing them, they really eat battery.
    10-12-2013 04:17 AM
  1. S4 Active won't charge properly
    By Anthony Cuello in forum Samsung Galaxy S4 Active
    Last Post: 06-13-2014, 04:13 PM
  2. My new Galaxy s4 has many problem please help :(
    By stramuzik in forum Samsung Galaxy S4
    Last Post: 10-13-2013, 04:40 PM
  3. Samsung Galaxy S3 - wf network issue
    By NedaSpasojevic in forum Samsung Galaxy S3
    Last Post: 10-11-2013, 04:13 PM
  4. Just Went From a Galaxy Nexus to an S4. So Many Questions...
    By Matthew Starr in forum General Help and How To
    Last Post: 10-11-2013, 02:15 PM
