Hi, I have had my S4 for a few months now. It has worked fine for these months although I've never been fully happy with its battery life I just assumed that was a common issue.
Basically, I could be using the phone doing just texting or reading a web page and it will shut off, the battery says its about 50% charged or something like that. This has happened three times in the last week so I don't know if this is a problem. Sometimes the phone can turn back on again but the battery on the phone starts to deplete at a much faster rate than before and it might only last an hour when I've got 40% charge. but sometimes It won't turn back on unless I plug it in when it seems to work fine.
However, I've seen a lot of people have had issues with the battery swelling and bulging out. I've seen pictures and some of them look extremely swollen. My Phone does have a slightly bulging battery and I know there is an NFC module built into the battery but this does seem to protrude out a little bit more than expected. There is a patch on the back of my phone on the outer case that is really scratched up even though I am very careful with the phone and this is also the bit that bumps out a bit. If I lay the phone down and push on the bottom by the home button - the phone flips up like its levering on the bump.
If I take the back off the phone and apply a very small bit of the pressure to the screen or around the battery - the bottom of the battery pushes out.
I would take a picture but there honestly isn't much to see because its not crazy big swollen.
Is this normal? Or do you think I have a problem - and if this is a problem. What is the best course of action to take to get this sorted out?
