1. anon(6174973)'s Avatar
    Hey guys. Its been a long time since I have posted here
    Anyway, I'm wondering whether this battery life of my s4 is normal or not. I'm using CyanogenMod 10.1.3 with a theme. I'm afraid that it is because of my usage that is causing this quick battery drainage.
    Sent from my GT-I9505 using Tapatalk
    10-17-2013 04:58 AM
  2. STSVA's Avatar
    http://img.tapatalk.com/d/13/10/17/esy3e7yr.jpg
    It would be helpful if you gave the list of things using battery with the% for each.
    Sent from my SCH-I545 using AC Forums mobile app
    10-17-2013 05:24 AM
  3. anon(6174973)'s Avatar
    Hi, thanks for the reply.
    10-17-2013 05:26 AM
  4. Shanicenicolle's Avatar
    I think its pretty normal. What was your screen on time?
    Sent from my *PURPLE* Galaxy S4
    10-17-2013 06:09 AM
  5. HPferoxCraft's Avatar
    What's the screen on time
    10-17-2013 06:09 AM
  6. anon(6174973)'s Avatar
    Roughly around 4hours.
    10-17-2013 07:00 AM
  7. ladyhaly's Avatar
    I think it's normal. Way better than mine and I'm using stock Touchwiz, unrooted.
    10-17-2013 07:02 AM
  8. Shanicenicolle's Avatar
    http://img.tapatalk.com/d/13/10/17/sy4adyty.jpg
    You're fine. That decent battery life. I get about that. Sometimes more, sometimes less.
    anon(6174973) likes this.
    10-17-2013 07:04 AM
  9. anon(6174973)'s Avatar
    Thanks guys. One last question. Should I use lte or HSDPA+?
    10-17-2013 07:10 AM
  10. Shanicenicolle's Avatar
    Depends which has a stronger connection in your area. I have pretty poor signal (sprint sucks) and keep lte on and still have decent battery life.
    10-17-2013 07:13 AM
  11. anon(6174973)'s Avatar
    Hmmm.. I guess I would just leave lte on since all I do is just reading and surfing the web.
    10-17-2013 07:19 AM
  12. Melinium's Avatar
    Since the day i have bought the Galaxy Note 3, i am saving a lot of battery on the S4.
    I use it only for phone calls, SMS and checking the mails, everything else is handled by the GNote3.
    10-17-2013 11:47 AM
  13. anon(6174973)'s Avatar
    So you use your Note 3 for entertainment purposes and your S4 for communication purposes?
    10-18-2013 05:01 AM
  1. Is root interfering with e-mail access?
    By Michael Fitzpatrick in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-28-2013, 02:06 PM
  2. Can anyone identify this app?
    By RavenMind in forum Legacy Android & Other OS's
    Last Post: 10-26-2013, 01:20 AM
  3. HTC One Battery Skipping Percents
    By jerickson55811 in forum HTC One M7
    Last Post: 10-17-2013, 06:03 PM
  4. Possible hints that there will be a countdown timer to when 4.4 kitkat is released?
    By electronicwiz1 in forum Legacy Android & Other OS's
    Last Post: 10-17-2013, 03:05 PM
  5. Had to exchange because of this
    By noteiii007 in forum Samsung Galaxy Note 3
    Last Post: 10-16-2013, 06:02 PM
