1. JayInNJ's Avatar
    I have been getting some bad battery life. I have the batteryguru app with most things turned on, gps off. I am at 56% after 3 hours 5 minutes. The screen is the biggest contributor at 34% and 45 minutes of on time. Second is my podcast player at 23%. Any suggestions? Can't figure out how to attach pictures in the android central app otherwise I would show all stats. I have the brightness set to auto.
    10-18-2013 11:39 AM
  2. KevLar72's Avatar
    If your phone is constantly searching for signal you will have horrible battery life!
    There's not much you can do about it . It's the carrier - not the phone .
    10-18-2013 11:50 AM
  3. STSVA's Avatar
    That seems like really excessive drain for 45 minutes of screen time. KevLar72 notes one possible source of battery drain - are you often in a weak signal area? Unless you really need the phone on all the time, if you do have a weak signal you can activate airplane mode to stop that as a source of drain. Also, check your wifi and make sure that's not on and looking for a signal.
    10-18-2013 11:57 AM
  1. Galaxy Note 2 Battery Drain Issue
    By Alberto Note 2 in forum Verizon Galaxy Note 2
    Last Post: 02-05-2014, 01:51 AM
  2. [Closed] Win a Seidio Innocell 4500mAH extended battery and cover for the Note 2
    By Kevin O'Quinn in forum Android Central Contests
    Last Post: 11-27-2013, 02:16 PM
  3. Buy 1 Anker battery for, $20 or
    By cmcfarland in forum Samsung Galaxy Note 3
    Last Post: 10-25-2013, 12:43 PM
  4. gs4 play store and battery life problems
    By mchockeyvette27 in forum Samsung Galaxy S4
    Last Post: 10-18-2013, 02:20 PM
  5. Android 4.3: Location Services battery drain?
    By pasei in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-18-2013, 01:05 PM
