1. mesmaryze's Avatar
    Hi everyone,
    I have a question. I am confused as to if my phone was unlocked or not. I called At&t and they gave me the unlock code. I travel often and used one of my foreign sim card to put into the phone as instructed. The unlock menu came on. I input the given unlock code and then it said "unlock request unsuccessful." But the confusing part is that it didn't go back to the unlock screen. It just went to the main screen ( with all my apps, emails, text like normal). So I turned off the phone and took out the sim and tried it again with the same foreign sim card to try the unlock again just in case I might have input the wrong code. However, the unlock menu never popped up again and just started up normally. I have no idea what happened? :/ Any help? Thanks for reading!
    10-22-2013 02:28 AM
  2. alfenton1988's Avatar
    What was the unlock code?
    11-23-2013 03:06 PM
  3. Garvin6600's Avatar
    I believe once you have Entered the unlock code. .you can swap SIMMS out at will. .
    No need to unlock every time you change your SIM ,.
    Good question though.
    11-23-2013 10:56 PM
  4. Garvin6600's Avatar
    Also. .
    Try putting in a different carrier sim even your old USA one and see if you can call..then you eill Know for sure.
    11-23-2013 11:04 PM
  1. Galaxy Note 3 - Disabling (Muting) Mic while Video Recording (Silent Video)
    By Super Turtleman in forum Samsung Galaxy Note 3
    Last Post: 04-07-2016, 06:22 AM
  2. Kindle app used over 10gb data in 12 days?
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 09-10-2014, 02:45 PM
  3. Samsung Galaxy Note 10.1 (2014) Is there cases available?
    By fofjjsr in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-29-2013, 08:27 PM
  4. Verizon Galaxy Note 2 - battery monitor help
    By Jonathan Rodriguez3 in forum Verizon Galaxy Note 2
    Last Post: 10-24-2013, 11:59 AM
  5. Galaxy S4 - i9505 sim free generic handset
    By mysticmeg in forum Samsung Galaxy S4
    Last Post: 10-22-2013, 07:36 AM
