1. forester0's Avatar
    I purchased an s4 roughly four months ago and just started having problems with the in call speaker. What happens is, if I make a call the phone dials and connects to the called number however there is no dial ring or sound from either the speaker or the speaker phone. A reset, battery pull or factory reset does not fix the issue however i noticed that removing the battery and sim card together does, however roughly 3 hrs later the same problem occurs and I need to remove the sim card again to fix and make a call.
    Is this a carrier issue or should I look at new phone replacement/warranty?
    thanks!!!
    10-22-2013 01:21 PM
  2. ladyhaly's Avatar
    I haven't been able to replicate the issue... What I would try to do in your position is get another SIM card to try it out.
    Sent from my GT-I9505 using Tapatalk
    10-22-2013 09:37 PM
  1. Overheating and charging issues after 4.3
    By Alberto Ortega in forum T-Mobile HTC One
    Last Post: 10-23-2013, 06:00 AM
  2. Replies: 1
    Last Post: 10-22-2013, 05:10 PM
  3. Replies: 4
    Last Post: 10-22-2013, 02:18 PM
  4. 4.3 Update Issue with TWRP
    By Tom Cantwell in forum T-Mobile HTC One
    Last Post: 10-22-2013, 12:45 PM
  5. HTC One X - Touch screen issue
    By Ilanit Coifman in forum HTC One X
    Last Post: 10-22-2013, 09:31 AM
