1. Joe_Perone's Avatar
    Is there any way to do this? I hate having to long-press it.
    Unrooted btw.
    10-23-2013 09:47 AM
  2. dm3ready's Avatar
    I came across an app named Switchr-Task Switcher on Google Play. I have not personally used it. However, in reading the description and reviews it clarifies that it only deals with Running apps...so, its different than Android default which multitask with recent apps.
    Hope that helps.
    10-23-2013 11:21 AM
  3. Chief G-Hawk's Avatar
    I wished there was a way since coming from an iphone 4S, i'm used to the long hold as Siri, and double click as the recently used tray bar open. But after using the SG4 for a while I've been getting used to it.
    10-23-2013 11:54 AM
  4. SupaBlackB's Avatar
    it probably takes as long as it would to double tap...you dont even hold it for a full second b4 the task mngr pops up....smh
    10-23-2013 06:01 PM
  5. Joe_Perone's Avatar
    BUMP! Any info on something like this?
    12-22-2013 02:45 PM
  1. Is it safe to update fw for note 2?
    By Zergslayer69 in forum Samsung Galaxy Note 2
    Last Post: 10-27-2013, 12:13 PM
  2. [GAME][FREE] Hit the Slime for phones/tablet/kindle
    By hittheslime in forum Android Apps
    Last Post: 10-23-2013, 03:34 PM
  3. Which CM Rom to get for Rogers' HTC One.
    By Pierre Leclerc in forum Rogers HTC One
    Last Post: 10-23-2013, 09:31 AM
