Power charge cable
Sep 14, 2013
22
I recently bought in a store a data and charging cable 3 meters long as more comfortable than the samsung original one but there is a big problem with the charging process, it does charge but really slowly, in 10 hours can be jusy charge a 20% and if I use while plugged it will finish quick and turn off even connected to electric supply
How can be this?are.not all cables valid? Only the one coming with samsung is valid? I need long cable and not the so shorter one
I use long time on the phone social networks, youtube using and many so battery drainage is a matter of a 3 hours more or less down to 0% so need to use it allways plugged to electric supply
I boughtn1 month ago but heavy use drains battery in just a couple of hours
Best regards
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,517
4,659
113
All cables and charger blocks are not created equal. I suspect the main difference is in the charging block. Compare the amperage listed on the chargers--you'll probably see that the one you bought is lower than the Samsung one.
firestartar
10
Best regards
Yes, thats right. Only the actual cable that comes in the s4 box will charge quickly. All other, even Samsung ones will not. Ive found that my old blackberry cable will quick charge as well.
Adamsberg
318
You're right, a longer cable with thinner conductor wires has more electrical resistance.
Amperage is inversely proportional to the resistance (Ohm's Law).
